96 XP Rec Build - Page 7
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 74
Thread: 96 XP Rec Build
  1. #61
    Frequent Poster Lakeside8's Avatar
    Aug 2013
    celina ohio
    Re: 96 XP Rec Build
    Quote Originally Posted by Matt Braley View Post
    Plus 2. That's what I was thinking. It all sounds good except for the shut off being too late.
    Just thinking because this set up is just like mine (I'm running 44s tho). What about the get in the return fuel like you had me do Matt? Does that have anything to do with rpms....i know sounds dumb lol
    Sent from my SM-G930V using Tapatalk
  2. #62
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    Quote Originally Posted by digital sol View Post
    Any updates? Did you wire the enhancer as a stand alone and delete the MPEM? Did you try the grey wire to drive the water injection? I am looking to do a similar setup with msd+waster injection but still reading up on everything. The stand alone option to delete the mpem sounds nice. I saw some people also used accel coil on plug wires in conjunction with the msd enhancer setup.
    So I finnaly got some time to finish the wiring on the water injection and to answer your question NO you cannot use the grey wire from the enhancer to drive the water injection. I just cooked my water injection. The trigger light came on for a while but I noticed it was solid and not blinking and as soon as i reved the engine.... that was it. Its dead. I tried driving it with the white wire wraped around a spark plug wire but its still dead.....
    Anyone have a MSD water injection controler for sale????
    1996 XP All the usual mods
    http://www.pwctoday.com/showthread.p...17#post4380117
    1996 WaveBlaster II 1200 conversion in progress
    http://www.pwctoday.com/showthread.php?t=477231
  3. #63
    Sep 2007
    Utah
    Re: 96 XP Rec Build
    ouch, expensive lesson, those things sell for almost $200 during the off-season.
  4. #64
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    This is what the MSD water controller instructions say....
    GRAY Connect to the Gray wire (tach output) on any MSD Watercraft Ignition. White wire will not be used when Gray wire is used.
    I was not using the white wire, just the grey wire from the MSD enhancer.... I'm guessing since the light was not pulsing the enhancer output is a variable voltage and once the output voltage/rpm got high enough, poof.
    I disconnected the power, hoping for a miracle, I will try it agian this weekend with the white wire.
  5. #65
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    Got a new controller and got the ski on the water this past weekend and it runs like a raped ape! Leave the line hard and pulls hard all the way. The water was too rough to get a good RPM read but its somthing more than 7100.
    Its finnaly running the way I had hoped it would. Reminds me of a miniture version of my old race GPR.
    Great power, hookup, handeling and jumping.
    Only problem now is my VTS stopped working. Now I just hear a click from the VTS motor every time I push the up/down buttons. Any ideas?
  6. #66
    Re: 96 XP Rec Build
    Pull the leads off the VTS motor and hook it directly to a battery. If it doesn't turn its the motor. If it does it's the VTS unit. You can either do a VTS fix or get a new one (which I'd personally do as they aren't that expensive).
  7. #67
    Dec 2011
    Niceville, FL
    Re: 96 XP Rec Build
    Click in both directions sounds like you blew the fuse.
  8. #68
    Re: 96 XP Rec Build
    Good thinkin Matt. Good place to check first being the easiest to diagnose.
  9. #69
    Oct 2012
    florida
    Re: 96 XP Rec Build
    To much bs with the vts I run the manual one off a hx .
    95 hx 787
    96 xp with miller motor
    92 gmc typhoon and 99 frc vette
  10. #70
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    Just got my impeller back from Impros. Looks brand new. Im using the stock GSX RFI pump and impeller. Stock it measured 16/25 and I was only able to turn about 6950 rpm. Its still slightly rich but I could tell the impeller was too steep so I didnt want to lean it out too much until repitching the impeller.
    I'm trying to get up to 7300 so Impros took some out of the trailing edge and made it a 16/22.5. I plan to take it out this weekend and see how she does.IMG_2012[1].JPG
