96 XP Rec Build - Page 3
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 74
Thread: 96 XP Rec Build
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    True Bore 40's with remote fuel pump
    1996 XP All the usual mods
    http://www.pwctoday.com/showthread.p...17#post4380117
    1996 WaveBlaster II 1200 conversion in progress
    http://www.pwctoday.com/showthread.php?t=477231
    Riverside, CA
    6
    Re: 96 XP Rec Build
    Quote Originally Posted by a1965gt View Post
    Thanks for the pics
    Bill M.
    Mar 2005
    Michigan
    Re: 96 XP Rec Build
    Novi doesn't offer that mod anymore from what I've heard.
    1997 Seadoo SPX---limited mod
    1996 Seadoo GSX--Cruiser
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    FYI, just in case anyone has ever wanted to know (like I have) the correct tap size for a Mikuni main jet is 5mm x 0.8 thread pitch.
    I didnt get the threaded fitting for the water regulator/RAVE valve with my pipe so I had to drill and tap the stock fitting.
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    Finally have the motor put back together.
    Here is a list of the modifications so far:
    Prok FA's with Fly socks
    Ture Bore 40 carbs
    Ported cyclinders
    Stock head for now
    Factory Pipe Spec 1
    97 SPX waterbox
    Homebrew water injection
    R&D tabs
    UMI bars KVPI throttle
    More to come
    Re: 96 XP Rec Build
    If you want buckshot 44 jetting specs our 800 is dialed. 63 gps on a good day, no porting.
    1994 1100 SJ - Dead
    1996 spec hx
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    Quote Originally Posted by 88kawi5fiddy View Post
    Thanks 88kawi but I almost have mine dialed in. One, maybe two pop off changes and maybe a high speed change and I think it should be dialed in (or very close). I will post my final settings in a week or two.
    The next item on the build sheet:
    UMI steering in excelent condition, should have it installed next weekend.
    Mar 2005
    Michigan
    Re: 96 XP Rec Build
    UMI, great setup!
  9. #29
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    UMI steering installed, hopefully I can take it for a test ride later today.
  10. #30
    Feb 2004
    Phoenix, AZ
    Re: 96 XP Rec Build
    Its been too chilly to ride lately so I havent been spending too much time wrenching but Santa was good too me and I thought I would post some picts of the parts I have picked up and will be installing in the next few weeks.
    In no particular order:
    Bullett Head, MSD Water Injection, RNR billet RAVE adjusters, big hub pump, R&D nozzle 82/85, billet 3 button switch housing, and single gage hood.
    And a special thanks to David Huges for multiple domes 43cc, 39cc, and 35cc, the Jet Dynamics #16 intake grate, and lightened PTO. THANKS DAVE!
    IMG_1208[1].JPGIMG_1209[1].JPGIMG_1210[1].JPGIMG_1211[1].JPGIMG_1214[1].JPGIMG_1212[1].JPG
