Results 1 to 2 of 2
    Jul 2003
    Belgium
    Boost control valve voltage
    Hi all,
    It seems I am not getting full boost after having had a short in the wiring harness. With the lanyard on I get like 7 volt over the boost control valve which is not enough to make it close (which would give more boost pressure). Is it possible to test the ecu boost control driver somehow? The valve itself is ok, it closes fine with 12 volt over it.
    Thanks for sharing your knowledge.
    K.
    May 2009
    Slovenia
    Re: Boost control valve voltage
    It is hart to check the voltage, You must have on one wire 12V to Ground, the another wire is ground from ecu so if ECu is not ok you do not recive the ground so it not clouse. Conect senoloind directly to battery and first clean it whit (break cleaner) than use same Crown, or WD 40 to lubricate it. Some time is the problem that is moving too slow or
