Just picked up an FX-1 Protc Pipe What carb settings
Results 1 to 2 of 2
    PWCToday Guru rib-x450's Avatar
    May 2010
    UK
    Just got a nice fx-1 as a nin runner and it came with two SBN's with different jets.
    Its stock appart from the protec pipe.
    What jets shoud I be running, can ayone advise please.
    Single SBN carb .................
    Kawasaki X2 with 800 Sxr Motor, carbs etc, Carbon reeds.
    PJS Nozzle, SXR Prop cut back.
    Factory Pipe and Blaster Chamber , Drilled out stock waterbox.
    Bored out West Coast manifold, bored to 47mm.
    Chopped Hood, Chopped -1.5 Inches off the back, seat filled in inch extended ride plate, UMI etc
    Cost more than it's ever worth but I love it.
    http://www.youtube.com/watch?v=4F7yjpmVE2E
    Resident Guru RenoJetTech's Avatar
    Apr 2009
    Reno,Nv.
    Re: Just picked up an FX-1 Protc Pipe What carb settings
    Nice find over there !
    Did you get it figured out already ?
    My belief is jetting shouldn't be to far from stock jetting, as I think Protec wasn't to big on having us to alter jetting or timing etc. to get more power like some pipe builders might.
    But yeah you're at sea level I suppose and now probably altered spark/flame arrester, and can only go so far out on high and low needles.
    '88 550-ride plate,intake grate,intake manfold,carb
    '96 GTX-1mm overbore,F/a's,intake grate,port timed for mid and top end
    '95 FX 1- usually take this motor to 753cc with exhaust porting and reeds
