Results 1 to 1 of 1
    Feb 2007
    Orlando FL
    2003 Honda Turbo F12X Part out 200 hours
    Have a whole ski w/ corroded ECU. The ECU is actually good but 2 Pins will have to be soldered back on. The turbo spins freely and has 2 bent fins. Rest of the ski is very clean. Compression is 120 pounds on all 4 holes. Spark plugs were just bought. The ski started and ran but threw codes (not 25) because of corroded ECU pins. I am sure there are more parts and feel free to offer on the ones listed. tried to match EBay as close as possible and still give some discounts to my fellow PWC Today fellers.
    Hull w/ title - 500.00
    Pump w/ reverse gate - 450.00
    intake grate and ride plate - 85.00
    Turbo - 400.00
    waste gate - 300.00 W/core
    Long Block - W/core 500.00 - W/out 750.00
    Electrical Harness W/ all sensors minus ECU - 300.00
    left / right mirror - 50.00 each
    Front hood - 75.00
    Seats - 60.00 for both (150 recovered with new marine vinyl)
    Gas tank - 50.00
    fuel system w/ fuel rails,intake, pump and injectors - 450.00
    Exhaust manifold and system to the pump - 300.00
