Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Sport open hx
    PWCToday Regular chris8103's Avatar
    Jun 2013
    France
    Sport open hx
    Hello everybody ,
    I am build a hx 951 with a 140mm pump.
    What is the good impeller to choice ?
    Oem sponsons are efficient or i would mount aftermarket sponsons ?
    Thanks for reply
    My first jet : GTX DI 2000
    Current jet : RXT 215 2007
    Assembly in progress GTI 215 2008 powered by chris
    Jun 2013
    France
    Re: Sport open hx
    What impeller pitch is the best one for this setup ?
    Nov 2009
    eustis fl
    Re: Sport open hx
    Hey Chris. You will definitely notice the difference with after market sponsons. So far the solas concord has been the impeller that has worked the best in my ski. I only rec ride so I do not know the rules, wondering if they will let you run a stock 155 seadoo pump. Cost is minimal, and it makes a huge difference over the 140.
    Jun 2013
    France
    Re: Sport open hx
    Thank you for this reply, i see beach house sponsons, they are good aftermarket sponsons ?
    What is the difference between beach house sponsons for hx and for xp ? Only the length ?
    Nobody mount a hx 951 with a 140 pump ?
    Re: Sport open hx
    that is a lot of power for that little pump. it will work, but a skat trak 148 would do wonders with a swirl.
    if you are dead set on 140mm pump, probably use something close to chris03hd kawasaki 1100 in HX build.
    1994 1100 SJ - Dead
    1996 spec hx
    resident guru HX RACER's Avatar
    Feb 2010
    PSL Florida
    Re: Sport open hx
    I run a 140 skat pump in my 1100. it handles the power great
    Jun 2013
    France
    Re: Sport open hx
    Quote Originally Posted by HX RACER View Post
    What is the pitch of your impeller ?
    Feb 2010
    PSL Florida
    Re: Sport open hx
    I'm not sure, it came with the pump. 16/24 maybe?
    PWCToday Guru HXLOCO's Avatar
    May 2007
    CHINO CA
    Re: Sport open hx
    Any videos from oct 6 sport spec?
    Frequent Poster Sev1n's Avatar
    Aug 2015
    Lake havasu
    Re: Sport open hx
    Quote Originally Posted by HXLOCO View Post
    hey tony, the only video i found was banned on youtube undersurfrats webpage. I saved a screenplay of both motos if you want i can try to email you them
