Page 8 of 8 FirstFirst ... 678
Results 71 to 72 of 72
  1. #71
    Oct 2013
    Ohio
    Re: ts77r hole in piston
    did you look at the 900L set up? Sounds like that is similar to what you have. You might need to play with a restrictor in the T if you add one, so you get flow to both places
  2. #72
    Nov 2016
    Ontario Canada
    The closest hose, the one i want to use to supply the resonator, comes from the head outflow and goes into the exhaust manifold.
    I will definitely add a restrict-or in my new hose to the resonator. the resonator shouldn't require much cooling, I think.
