ts77r hole in piston
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
    Cottage Grove, MN
    I just bought a tsr 770 last night, and I wasn't thinking when I removed the cylinders to inspect the crank, but now I cant leak down test the motor because I'm a big dummy. I was wondering if you guys could try to help me diagnose this hole before I rebuild it. It did not come with the spark plugs so I don't know what the plugs looked like, but both pistons where scored and the pto cylinder had melted piston smeared and stuck to it. I'll post a picture of the motor in a bit. No carbs ether so cant inspect those.
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    94' Montego (my first) sold
    95' Daytona sold
    95' Daytona parted out
    95' Barracuda sold
    96' Montego sold
    96' Monte Carlo 900 sold
    97' Daytona 1000 sold
    99' TS770R sold
    Cottage Grove, MN
    Re: ts77r hole in piston
    Here is the motor. Pictures are of both cylinders, both pistons, and the head. Bottom end is good, head is good, but cylinders and pistons are junk. Might be able to bore out the cylinders but I'm probably just going to do a complete sbt top end. Still need to figure out why this happened though so I don't waste my money.
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    95' Daytona sold
    95' Barracuda sold
    96' Montego sold
    99' TS770R sold
    PWCToday Newbie Whossharkbait's Avatar
    Jul 2015
    Nebraska
    That's what mine looked like when my pto crank seals went bad. It sucks but I would put it back together and do a leakdown on it. Unless you are just gonna go reman. Also while it's apart go ahead and rebuild the carbs.
    99 Tsr 770: gps 59.3, kawi 1100 limited motor, dried out stock pipe, mikuni 44s, Ada head 145psi, 148 mm pump.
    94 barracuda custom: 770 limited motor, 2* static advance, vforce delta reeds, milled head 165psi, molded pump inlet grafted on with 146 mm pump.
    PWCToday Regular Goodchildren's Avatar
    Jul 2012
    Joliette, Quebec, Canada
    why not replaced complete seal kit for sure no more problem after rebuilt
    Tigershark Daytona 640 1995
    Tigershark 644 1993
    PA
    Lean-outs are caused most times by air ingestion passed bad seals. Time to do soup-to-nuts on this one, or you'll just repeat history.
    PWCToday Regular PsychoSchematic's Avatar
    WI
    Engine literally only has a few hours on it, suspecting large air leak somewhere, new sbt crank seals were installed this spring, along with top end kit. When you find the leak let me know where I f'd up. :smack:
    1997 TigerShark Daytona 1000: Arctic Cat green, hydroturf, Beach House sponsons, TDR exhaust, 16/21 Skat Trak Slimline impeller, 1100R steering nozzle. More to come
    1999 TSR 1100
    1994 TigerShark Barracuda: Solas Super Camber impeller, Black Magic intake grate, Rend ride plate, JRE Lightweight Flywheel, DG Tri-Oval waterbox, beach house.
    Cottage Grove, MN
    So general consensus is bad crank seals? I know a rebuild with new gaskets is basically mandatory in this situation, and I know it was lean condition, but I'm trying to figure out if it's crank seals, bad gaskets/crank case sealent, or dirty carbs. I do not have the carburetors for this ski so I am unable to rebuild/inspect them. I bought the ski as a project. But normally a smart technician would have done a leak down test before starting to disassemble. But I prove once again that I'm a big dummy lol. My consern is that now that the original seal between the cylinder and crank case has been broken, even if I reassemble the motor I'm not going to get an accurate result from the leak down test. It could how ever show me if the crank seals or bottom end gaskets where leaking I guess.
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    95' Daytona sold
    95' Barracuda sold
    96' Montego sold
    99' TS770R sold
    Jul 2015
    Nebraska
    You can do a leak down but you're not looking for it to hold pressure at this point. what you're looking for is the leak, so get a bottle of soapy water and start spraying, the leak will appear. At this point because you don't have the carbs I would just do a complete gasket kit reseal the cases get some carbs and go ride it like you stole it.
    Cottage Grove, MN
    I pulled off the mag cover to get the fly wheel off, and there was some oily stuff on the bottom, it looked like oil and was slippery like oil, but it didn't smell like oil. I can't get the damn flywheel off ether. I'm using a puller, heated up the flywheel, and pounded on the puller and still nothing.
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    95' Daytona sold
    95' Barracuda sold
    96' Montego sold
    99' TS770R sold
    ***** to pulll sometimes... use an air gun
