Js440 js550 and 650 parts . Mostly oem
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
    PWCToday Regular Lethaljs440's Avatar
    Jun 2016
    Rathdrum Idaho
    Bunch of stock 440 and 550 parts . Two full circle bottom ends with cranks , too much to list so look thru or ask . Located in Idaho . I can ship and have paypal . Thanks
    Jun 2012
    Re: Js440 js550 and 650 parts . Mostly oem
    any 650 SS impellers?
    Jun 2016
    Rathdrum Idaho
    No sir. , no 650 impellers .
    Jun 2016
    Rathdrum Idaho
    650 parts are . Good cylinder jug and stock red head . Cylinder needs honed . 650x2 oil pump and tank level stick , stator cover with o ring , Kehnin cdk2 carb with manifold and rebuild kit , bed plate . 89-92 x2 throttle cables 2 used but work fine .
    PWCToday Regular TripleRRR's Avatar
    May 2010
    On the big fish
    Can you give me prices for the Coffman pipe(550sx), starter(550), 550 pump. Not sure of the carbs but do any fit a 550sx, if so how much. Thanks, Rich
    Jun 2016
    Rathdrum Idaho
    Coffman pipe needs two of the three bolt holes welded then re tapped for a m8 1.25 thread . I'd do 75$ on it shipped , pump is in great shape with newer wear ring and skat 15.5 pitch . Looks like the exit nozzle is bored out also . I'd do 140 for it complete shipped . Brand new 550 starter with o ring 65$ I have 3 bn38 carbs a sbn38 carb brand new never used with instructions . Also a Kehnin 38mm all can work with the correct manifold .
    Jun 2016
    Rathdrum Idaho
    I will trade for 650 x2 parts also !
    Jun 2016
    Rathdrum Idaho
    The Coffman pipe can also be used with 1' longer stainless studs with nuts
    Hutchinson, MN
    Any stock js550 flame arrestors?
    Sent from my HTC6525LVW using Tapatalk
    Jun 2016
    Rathdrum Idaho
    No 550 ones . Couple 38s
