    PWCToday Regular waytoofast's Avatar
    Jun 2008
    stockton CA
    need someone with a computer to help me with MSX 110 north cali
    hi i bought it and says over heating , first check engine light then over heat sign , and the throttle is not working at all no response thanks in advance
    06 Yamaha 1100
    97 xp 800
    95 900 zxi
    01 saturn
    97 dakota 4x4
    1996 cbr 900 RR (OLD SCHOOL)
    Sin City USA
    Re: need someone with a computer to help me with MSX 110 north cali
    If it is too hot it wont respond to throttle because the temp sensor puts it into "limp mode" so you dont completely ruin your engine. Find and fix the cooling problem.
    Jun 2008
    stockton CA
    its doing it at start up , the check engine light for 5 sec then the temp icon ,, and no throttle at all ,
    06 Yamaha 1100
    97 xp 800
    95 900 zxi
    01 saturn
    97 dakota 4x4
    Sin City USA
    Disconnect temp sensor, try again. If it solves issue, ride and keep an eye on the pisser temp for a while. If it is OK, I would suspect a bad sensor.
