Bog - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Bog
    PWCToday Regular 440 Nut's Avatar
    Feb 2014
    SoCal
    Re: Bog
    Quote Originally Posted by JonnyX2 View Post
    I wouldn't waste money on a rebuild kit to chase a low speed bog. The FIRST thing you need to do is see what your jetting is.
    You need to know what size needle seat, what spring, and the high and low speed jet sizes. It could be as simple as pop off is slightly off or an adjustment of the low speed circuit. Open her up, get the info and report back.
    If I open up the carb won't I damage a gasket if it hasn't been opened in a long time ? I just wanted to have a kit on hand so I can reassemble carb right away. I'm not familiar with this carb . My other two 440s have the round body carbs. I'm at my house in so cal now and the ski is at my river house in Arizona . I guess I'll mess with it when I'm out there in a couple weeks. The only time the bog really bugs me is when I'm taking off from shore it takes a few seconds to get cleared out which means I'm dragging behind the ski for a bit before I can stand up.
    Thanks for the info and I'll report back in a couple weeks .
    Sin City USA
    Re: Bog
    No gaskets in the jet side that will be damaged.
    Feb 2014
    SoCal
    Re: Bog
    Well I finally got around to pulling the carb and putting a rebuild kit in. Bog is gone. Now the only problem is it's a little tricky to start. Unless I give it just a touch of throttle it won't start. Any more than a touch and it floods. I'm still playing with the low speed mixture screw but it's not there . My other 440 fires right up without touching the throttle . Any ideas?
    PWCToday.com Is My Home Away From Home freekstyle's Avatar
    Aug 2007
    Re: Bog
    Did you change the inlet size or spring?
    Feb 2014
    SoCal
    Re: Bog
    No I just cleaned it and put a rebuild kit. It came with four different springs and wasn't sure which direction to go so I left it. The large jet looked like it said 100 on it and I couldn't read what the small jet was. It looked awful
    Big though .The hole looked almost as big as the secondary jet which surprised me..I think the carb is a 44 since the flame arrest says 44 on it. It rips out of the hole now but just has a certain way to start it . My kid got stuck yesterday because he flooded it. I had to show him the starting procedure.
