How are these new Lithium Ion batteries in a PWC? - Page 2
Results 11 to 13 of 13
    PWCToday Guru starlight's Avatar
    May 2013
    North West Ohio
    Re: How are these new Lithium Ion batteries in a PWC?
    I use Shoria Lithium batteries in my 750 since 2013 with out any problem, only time the battery get charged is when i ride the jetski .
    1998 KAW SXI PRO
    1996 KAW SXI : Hydro Turf, Hot Products Handlebar, ODI Grips, Stock Sold 3/9/16
    1990 KAW 550SX : Skat Trak, A.M. Handlebar, ODI Grips, Stock
    1995 seadoo HX
    89 650sx stock pipe mod. Sbn44, A.M Handlebar, OGrips
    subnsxr's Avatar
    Lakewood,CA
    Quote Originally Posted by X2mafia View Post
    Lith batteries are great when your running total loss systems. Other than that stay away. They have their own specific charging algorithms. Ive been told battery tenders in particular varries in amperage as it charges it and its a very low charge. They also need to be drained all the way down and charged all the way up. Our charging systems on the skis have a amperage rating to aggressive for the lith battery. Watched my friends burn through WPS, Battery tender, and shorais like its going out of style. Ive had many discussions with my battery rep from my shop and bottom line its not worth it for non total loss. If your running a stand up the deka etx9 weighs in at 6 lbs and has plenty of CA to start even high comp motors. Just strap it down with a piece of a pool noodle between the straps and the battery on top and your set.
    my battery render lithium battery just died, only 8v after 3 months, I ride salt and I read that to fully kill a lithium battery you should submerge in salt water.
    subnsxr's Avatar
    Lakewood,CA
    Quote Originally Posted by subnsxr View Post
    It appears that my failing starter is what killed my lithium battery.
