Js 550 part out
Results 1 to 10 of 17
Thread: Js 550 part out
    PWCToday Guru 1100offshore's Avatar
    Dec 2004
    jacksonville/ tampa
    Js 550 part out
    I have a lot of parts and almost all of them have been cleaned up and some repainted w epoxy paint.
    Aftermarket parts i have are:
    -PJS exhaust manifold cleaned
    - uk exhaust, possibly an ocean pro or kerker. It has a steel header pipe.
    - lees racing scoop grate, cleaned and painted w white epoxy paint.
    - mako 60 ss impeller- excellent shape.
    - DG tri oval water box
    I have everything else except the impeller housing and head. Parts will be cleaned up b4 shipped to u.
    PM me w wut u need and your offer. If you want pics send your # and i will text them.
    Top Dog Virgin Air's Avatar
    Mar 2012
    Wa.
    Re: Js 550 part out
    why 2 threads?
    2000 750 Sxi Pro. Factory Limited pipe, 40mm mikuni's, 13/18 SXR blade, Kommander head, Newmiller Freestyle ported #22 cylinder, lightened flywheel, aquavane & Worx ride plate, trued hull, AC handlepole. 51.8 mph
    1993 550 Sx. PJS intake & 15.5 skat.
    Dec 2004
    jacksonville/ tampa
    Re: Js 550 part out
    Quote Originally Posted by Virgin Air View Post
    why 2 threads?
    I have no idea what happend.
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    Re: Js 550 part out
    Pm sent
    Sent from my SM-G860P using Tapatalk
    Dec 2004
    jacksonville/ tampa
    Re: Js 550 part out
    Ok heres a more detailed list. Please just make me offers, im not married tothe stuff. All profits go to 750sx bouy chaser project.
    -Ebox that will have fresh epoxy paint. Looks new on the inside but 1 spark plug wire has a broken fitting... The white threaded plastic piece. Havnt tested the coil but will try to soon.
    - fuel tank cleaned inside and out
    - gas cap
    - FE cap w o-ring
    - flywheel
    - pump w undamaged vanes and good bearings
    - reducer cleaned and fresh epoxy paint with harware for steering nozzel
    - hood strap w harware
    - handlepole bracket w harware and rubber bumper
    - handlepole pivot bolt w bushing
    - rev limiter works fine
    - water fuel seperator good shape
    - motor mount brackets cleaned up w wirewheel
    - dash panel and backer w hardware
    - hood that will need sum repair. Pay shipping and its yours
    - start stop switch w wiring
    - steering plate w clamps
    - steering assembly
    - handlepole w ripped pad
    - bottom end w coupler still attached to crank. Will come with damaged cylinder... U seperate them
    - stator, not tested yet
    - pole spring
    - stock finger throttle
    - stock ride plate
    - stock sponsons
    - steering cable bracket
    - rev limiter and WFS bracket w harware
    - drive shaft assembly w good bearings.
    - stock bilge assembly very clean
    - waterbox straps
    - fuel tank straps
    - fuel pickups w hoses
    - steering cable guides
    - pump hardware and inserts
    - exhaust thru hull fitting with hoses
    Ive got more im sure plus the aftermarket stuff mentiond in first post.
    Frequent Poster AirJunky's Avatar
    Sep 2015
    Liberty Lake, WA
    Re: Js 550 part out
    What carb do you have?
    Bill
    Current ride is an almost stock 94 550SX
    Current project is a 92 Super Chicken SC650
    My JS550 build
    . - SOLD
    Dec 2004
    jacksonville/ tampa
    Re: Js 550 part out
    Quote Originally Posted by AirJunky View Post
    Its a BN 38 but just ordered a rebuild kit and stainless bolts for it to put on my 650... I suppose you could make me an offer for it with fresh gaskets, diaphrams and stainless hardware.
    Dec 2004
    jacksonville/ tampa
    Re: Js 550 part out
    Bump. Nobody needs 550 parts?!
    Jun 2014
    cranford
    Re: Js 550 part out
    Do have the cylinder?
    Dec 2004
    jacksonville/ tampa
    Re: Js 550 part out
    Cylinder and head are no good.
