X2 750 setup question
    Jun 2016
    Lake Stevens, Wa
    Well I got a project with a running 650 motor and I thought I had it figured out how I was gonna build it (single 44mm carb, westcoast/coffman exhaust, 15.5 SS impeller). Now I found out I have two 750 motors in my stock of motors (they probably need rebuilds). Is a single carb still best for the 750's or are duals the way to go? Also what Impeller now should I run? 650 pump housing.
    Thanks for any info, I did a search and found lots of info on more modded builds than I want to go. (I want carb, exhaust and impeller upgrades)
    Tyler
    Resident Guru rock_smasher's Avatar
    Jun 2009
    PW, CO
    Re: X2 750 setup question
    I just finished my 750 X2, run a single 44 and coffmans with a cut back 9/15 hooker, its a beast.
    I prefer the single carb- easier to tune (and reach) and 1/2 the cost to rebuild. And, I really dont need the extra bit of whatever you get with duals. If I was racing or freestyle stuff, maybe.
    Those who will beat their swords into plows, will plow for those who do not.
    I got 99 sockets but a 10mm aint one
    PWCToday.com Is My Home Away From Home Camasaki's Avatar
    Mar 2013
    Palm springs ca
    single 46 sbn on mine
    Jun 2016
    Lake Stevens, Wa
    Thanks for the info
    PWCToday Regular dmaxryan10's Avatar
    Mar 2015
    Western NC
    just finished my flatdeck build, I did a 750sp and twin carbs. it's the bomb for low end. runs great.
    js550 with 650 swap custom wrap
    x2 750 swap flat deck
    01 superjet stock
