Removed PV cover on gp800 and PV is missing, but engine runs great...?? - Page 2
Results 11 to 20 of 21
    I dream skis needforspeed's Avatar
    Sep 2008
    New Jersey
    Re: Removed PV cover on gp800 and PV is missing, but engine runs great...??
    Quote Originally Posted by Shaun23a11en View Post
    Here's the piston. Would I be in trouble if I used this based on the condition that can be seen in the picture knowing that it did produce 135 pounds compression?Attachment 503523
    I don't think that it the piston "skirt"....the skirt is the bottom of the piston not the top with the rings?piston.gif
    If it aint broke...don't fix it!!!!
    Top Dog Wet Wolf's Avatar
    Nov 2001
    Spokane, WA
    I would replace that piston.
    Bruce Wolford (509) 280-5444 - Pump Performance
    http://www.wetwolf.com
    PWCToday Newbie Shaun23a11en's Avatar
    Jul 2012
    Lomita, ca
    yea i thought i was looking at the skirt, it was late at night lol. I am not going to replace the piston as the engine has been running fine and the compression is very good. Why would you replace it Wet Wolf?
    Yeah I would replace it too if I was already this far, it's not like you have to bore the cylinder or anything.
    PWCToday Regular jason 650sx's Avatar
    Jun 2015
    nc
    Okay this is my first post love the site. This is what I found today when I trying to put wave eater Clips in my GP 800...Can some one please tell me where the other half of the power valve is???
    Jun 2015
    Hungary
    Hi guys,
    I'm new here, but read long time ago.
    My GP800R has same problem. I found the half PV in the cylinder. The other half went out on the exhaust. (The piston damaged a little bit. I will put a new one.)
    I rebuilt the engine 40 hours ago. New crankshaft, pistons, etc. I also put a new SBT powerwalve+safety link.
    Possible the wrong PV? Maybe material defects?
    I checked the other walve, and noticed the chrome coating is damaged some places.
    I can show you later.
    What do you think about the SBT power valve?
    Maybe the OEM is better?
    Thanks in advance for your answers.
    Marci
    Jun 2015
    Hungary
    Quote Originally Posted by zeppa View Post
    Hi guys,
    Marci
    Here are the pictures.Fajl_001.jpegFajl_002.jpegFajl_004.jpegFajl_003.jpegFajl_005.jpegFajl_006.jpeg
    I forgot to write:
    The bore size is STD (80.012mm). When I rebuilt the engine, I checked the distance between PV and piston. It was 0,5~0,8mm. (impossible to piston hit the PV.)
    Hi guys,
    Marci
    Basically just a sh!ttay design !
    Jun 2015
    nc
    Ya I don't think I'm going back with stock PV in rebuild. I just hope the bottom end is trash free.
    Jun 2015
    Hungary
    Hi guys,
    I repaired my PWC. I designed it, and made stronger PV. This never will broken. Canít drop into the cylinders. Now working fine.
