Results 1 to 10 of 11
    PWCToday Regular badrocco16v's Avatar
    Oct 2013
    Detroit Rock City
    JS550 winter build
    Hello all,
    Sorry for holding out on you but I wanted to water test this machine before putting up a build thread to avoid having a 6 month thread that never wraps up.
    This started out as an 84 JS550 I bought from another PWCtoday member a couple of years back. I wanted to shorten the handle pole and install a rear exhaust over the winter and said, "why not put down some new paint too?"
    Here is what I started with.
    Got the engine out and flipped it upside down. The hull has seen better days. The impeller is a minty scat 15.5 and the bearings needed a little love.
    Now for the rear exhaust work.
    I found this sawzal bit works wonders for deturfing a hull. Just be carefull...it will cut into the SMC faster than I imagined.
    Next, test fitting a shortened handle pole. The second pic is it riveted and glassed back together.
    Aluminum exhaust pipe test fitted in place.
    Next my garage is converted to a body shop. Lots of sanding and glassing.
    First round of paint.
    To be continued.
    '84 JS550 Big Pin 750 twin carb, big pump swap, custom pipe by me
    '85 JS550 bone stock backup/loaner
    Oct 2013
    Detroit Rock City
    Re: JS550 winter build
    Here's the hull after some paint on the top.
    The motor dropped back in nicely.
    Jun 2014
    Seattle
    Know the paint color? I plan to do my ski up orange and purple, that orange looks nice.
    78 JS440
    -Ocean Pro Finned Ride Plate
    -Westcoast Intake Grate
    -SCR Ported Cylinder
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    -Skat~Trak 16.5 SS Impeller
    Oct 2013
    Detroit Rock City
    Oct 2013
    Detroit Rock City
    Quote Originally Posted by TheJS440 View Post
    JS440, The paint is Lucid Technologies quadruzzi concrete orange. I bought a gallon a year or so back to paint a race car and used some of the left overs for the ski. I was thinking about doing yellow, but had the paint on the shelf.
    Frequent Poster Sxsixfitty's Avatar
    Nov 2014
    Michigan
    Looks great!
    Frequent Poster AirJunky's Avatar
    Sep 2015
    Liberty Lake, WA
    Cool build. I liked it nekkid better.
    Bill
    Current ride is an almost stock 94 550SX
    My JS550 build
    . - SOLD
    Oct 2013
    Detroit Rock City
    So I've been holding out again. I picked up a big pin 750 and pump a little while back. One of my coworkers needed a running 550 motor so I started my swap a little ahead of plans. I already had all of the RHaas stuff for the engine and pump swaps. There was a slight hiccup in getting the x2 driveshaft ( i got shafted on CL) but now I have that too.
    Last weekend I decided to bite the bullet and do the engine half of the swap. All I was missing was a pipe. There has been a ragged FMP gold series pipe on the shelf from my old KX500 that I had no use for. I decided to section it out and make a pipe for the time being. Here are some pics of that franken pipe in progress. Once i got the pipe welded up (excuse the crappy welding, it was me running the torch rather than the guy at the shop who does proper finish welding) I mounted the 750 ebox toward the LH side per Kurt's recommendation and took it out to the nearby lake.
    The first water test was oddly successful but a little disappointing. The motor would not overpower the 15.5 scat in a 550 pump. Granted I didn't have the stones to top it out, it did have an impressive top end. Either way it was still fun.
    The next step is to take some of this fine 304 stainless and craft a pipe that fills up what little room there is between the 550 hull 750 motor and 550 fuel tank. Kurt has also offered some advise regarding the volume and packaging of this pipe. I plan on following this advise when making the real deal.
    It will probably be 2 months before I can do the pump swap so in the mean time I hope I can get the engine running strong.
    Oct 2013
    Detroit Rock City
    I have some headway on my custom pipe.
    After months of procrastination and waiting for my friend's cnc plasma cutter to work, I just made a wooden template and plasma cut it by hand.
    Tig welded the halves together with an NPT bung to inflate it from.
    Then proceeded to fill it with water.
    Here is the first test fit after triming off the ends.
    Since I had the motor out, I went ahead and did the big pump swap. I'll tip my hat to RHAASS as the kit included all of the special fasteners and is a fairly simple installation. Anyone can do this.
    The final fitment of the pipe is still a work in progress. I'm planning on doing a center bleed to keep the noise within reason. I hope to post some more photos of a running ski in the next few weeks.
    *PSO kids don't try the hydroforming at home. It is too awesome.
    SE MI
    Any ride reports of this bad boy?
