Any input on a PJS VXL 900 ??
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
    Mar 2005
    Santa Barbara, Ca.
    Couldn't resist picking one up ... I runs but pump is shot.
    Anyone ride one of these before? Info on motor? Specs?
    I know there aren't many left and parts are scarce but who knows...
    Thinking of maybe putting it in an X2 ?? 110 hp 2 cylinder
    Thanks!
    Jun 2014
    Seattle
    Re: Any input on a PJS VXL 900 ??
    Pics!!! Pics!!!
    78 JS440
    -Ocean Pro Finned Ride Plate
    -Westcoast Intake Grate
    -SCR Ported Cylinder
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    -Skat~Trak 16.5 SS Impeller
    Mar 2005
    Santa Barbara, Ca.
    Anyone interested in the hull before I cut it up??
    Jun 2014
    Seattle
    Interested in pics of the hull before you cut it up.
    78 JS440
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    Mar 2005
    Santa Barbara, Ca.
    Quote Originally Posted by TheJS440 View Post
    ok tomorrow
    Mar 2005
    Santa Barbara, Ca.
    Bump. Anyone have any info on this thing? Web is pretty slim
    Hull is available in So Cal
    Mar 2007
    Is Everything!
    Very cool, with a bada$$ belly full of fire. Had a little time left after lunch so I snapped a few. Its here waiting for you...
    Country approves, . Sea (pun intended), couches are good for something!
    BinSB, be advised wherever this baby lands is going to forever be known as Jugs
    EDIT- with a little luck, hopefully this thread can become a great source of info and specs for these really cool PJS machines
    PWCToday.com Is My Home Away From Home Matt Jones's Avatar
    May 2010
    Charlotte, NC
    http://www.ebay.com/itm/PJS-SeaJet-V...-/120758407365
    Here is a pump for you...I actually almost bought the same ski from my buddy here in NC but he had a blaster project I wanted instead, so my buddy as wizard's powersports bought the Seajet and parted it out.
    Chicago / Portage, MI
    mtrhead gave me some feedback on those a while back. Big and lazy engines he said based on the port timing and something about the cylinder spacing I believe. wmazz might also know about them too. Either way, that's a cool rare ski! I'm responding before I check the engine pic, but it has a side draft right?
    Edit: yea I see it does. Also I wonder how these handle compared to the xir.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    Mar 2005
    Santa Barbara, Ca.
    Anyone else know anything about these boats?
    There is a 3 button security system that cuts the spark ... mine's working now but I wish I knew the code and how to enter it.
    Rear pump bearing is literally gone and impeller pulled forward ruining itself on the pump shoe. Shoe fixable ... prop not so much.
    Pump mounts to a flat plate with 4 bolts and O rings for the waterlines and bilge ... super easy to change props!
    Have another pump assembly coming.
    Huge cylinders ... 85mm I think ... 165 psi in both with a little oil ... been sitting awhile.
    Also has a really nice top-stop billet steering head.. upper hull is bi-axial S glass... nicely made. Bottom of hull has some special sponsons molded into the rear strakes. Look forward to a test run!
    Come on...someone must know something
