WTB - YAMAHA 1200 65U Block/Core
    Feb 2012
    Bluffton / HHI, SC
    I just bought a 2000 Yamaha LS2000 Jetboat with dual Yamaha Non Power Valve 1200 motors (65U). Both motors are bad
    One motor had catastrophic damage and I am looking for a core for exchange with no holes or cracks in it.
    Let me know what you have! Thanks!
    Dec 2008
    va
    Re: WTB - YAMAHA 1200 65U Block/Core
    I have 1 800.00
    Jun 2016
    Cocoa, FL
    I have a case for a 1200 NPV. Its a clean bare case no crank.
    You better rebuild both mid shaft assemblies while the motors are out. A customer of mine almost had his LS2000 sink cause of a leaky one. Also update the jetting and do the balanced return mod on both carb racks.
