About V-Force Reeds
Results 1 to 10 of 11
    Tech Guru Resident Guru
    Feb 2002
    Fort Mohave, AZ
    About V-Force Reeds
    We often write tech update bulletins for our customers … it gives me no joy at all to write this one.
    We recently did a full buildup of an SXR800 engine for a customer. While we normally use stock reed cages, this customer provided V-Force reed cages that he wanted installed. After assembling the engine, we conducted our standard air-leak test to find that the engine had several catastrophic air-leaks (that means the engine was leaking air out faster than we could pump it in). In short order, we found that the sealing surfaces of the V-Force reed cages (against the inlet manifold) were profoundly “unflat” and they leaked all the way around (even with the supplied gasket and gasket sealer). After disassembly, it was clear that the multiple surfaces on the reed cage were all mismatched, and serious surfacing would be needed. We ended up having to machine about .015” (.38mm) off the collective reed cage surfaces to get “what appeared” to be a flat sealing surface. This surfacing had to be done very carefully because the two reed cage sealing surfaces needed to be square and parallel to reach other in order to seal against the stock “one-piece” inlet manifold. If a well-meaning customer would have just bolted on these same V-Force reed cages, the resulting air leaks would have caused un-ending starting/carburetion/jetting problems, to say nothing of delivering scored pistons every time it got run at extended high-rpms. This is particularly frustrating for us, because any time a customer contacts their dealer (or the manufacturer) for V-Force jetting info, the standard answer is “contact your engine builder”.
    Well ….. This is your engine builder …. And based on our experience, V-Force reed cages do not have “jetting” issues, they have catastrophic air-leak issues that need to be resolved. Given this, we will strongly recommend against the installation of these reeds into our engines. For those that already have V-Force reed cages, we strongly recommend to pressure test your engine before going on one more ride. If you have huge air leaks (as we found), those leaks must be sealed 100% before running your engine. Visit this page for more info on pressure testing your engine. http://www.groupk.com/tec-airleak.htm
    It is our greatest hope that the folks at V-Force see this as an important issue that needs to be immediately addressed … and addresses it. Please find attached some photos that illustrate.
    Respectfully, Harry Klemm Group K
    www.groupk.com
    Apr 2006
    Las Vegas
    Re: About V-Force Reeds
    I never liked VF3s. VF2s bolt up to the manifold just like the stock reed cages so you don't need to worry about the mating surface, at least on Yamahas they do. Not only that, VF3 cages are made out of cheap plastic. I hydrolocked an engine once and the entire cage collapsed, I had to replace the whole thing.
    I seriously doubt anyone from Moto Tassinari will notice this. They're a pretty big company and I'm sure the PWC market is small for them.
    Top Dog sea-one's Avatar
    Aug 2011
    Dallas tx
    agreed on the VF2
    2004 Rxp Stock Motor with other light mods
    1996 Xp Resurrected july 2014/SOLD 2016
    1991 Kawi 750cc Big pin Twin Carb Sport Cruiser Custom (Resurrected Feb 2015 completed June 2015)
    2000 XP Saved Spring 2016- Resurrected July 2016 as new
    2002 Seadoo ISLANDIA/Sold
    CANDoo Pro system
    Harry,
    Is this issue a moot point for anyone running reed spacers, or would the same sealing problem remain?
    Apr 2006
    Las Vegas
    Same problem.
    Quote Originally Posted by tshank123 View Post
    Same problem.
    Well that's not good. Maybe I should return these and replace with the VF2's then. I've never heard anyone else with this issue but it certainly raises a red flag. Maybe it's an isolated incident? I can't imagine Tassinari putting out a product that is that bad.
    Apr 2006
    Las Vegas
    I don't think people normally run reed spacers with these because they kinda have the spacer built into them. What are you using them on? An SXR?
    Running it on my Seadoo XP 1100 conversion. Guys were having issues with them chipping and coming apart without the spacers. Plus, I needed the extra pulse fitting the spacer provides for the Mikuni 44 carbs going on it.
    Dec 2006
    Mesa AZ
    Quote Originally Posted by Alter Ego Trip View Post
    You could always just check them instead of throwing parts at a maybe problem.
    Quote Originally Posted by bored&stroked View Post
    What!?! Inconceivable.
