Quick question - 650sx
    I dream skis silverado87's Avatar
    Aug 2012
    Brick, NJ
    Harry...I know from reading your website, it sounds like you guys are big proponents of the 42 Keihin carb...I have a 650sx with a sudco 42, factory pipe, jetinetics flywheel, not sure if the motor has been ported or not..I read in another post that the jets should be 82 and 155...any advice on where to set pop off at and screws? Also I will mention that I believe the seat has been bored out to a 2.0...most likely by you guys...thanks in advance.
    1988 650sx- ground up resto, RAD flywheel, Solas prop, Jet Dynamics ride plate, Worx intake, Keihin 42 carb, Factory pipe, Jettrim mats-44.6 MPH
    http://www.pwctoday.com/showthread.p...light=88+650sx
    1992 550sx "567" ground up resto, Group K sleeper ported 650, 750 pump w/ Skat 9/17, Sudco 42, stock mod pipe, RAD flywheel, JRE quick steer, Jettrim pads- 48.5 mph
    http://www.pwctoday.com/showthread.p...light=92+550sx
    2009 SXR-​ bone stock
    PWCToday Guru kawipilot's Avatar
    May 2002
    Lake Havasu of course
    Re: Quick question - 650sx
    I am sure Harry will correct me if I am wrong. But I would start at 18-20 psi pop off, and 1.5 turn on the bottom, and 1 turn out on top. If pop off is too high, it will run out of fuel at idle, but the factory pipe pulls harder (stronger signal), so I usually run higher pop off. It gives you a snappier hit off the bottom.
    Aug 2012
    Brick, NJ
    Thanks Kawi...I got some good info from Jdpilot on this site, and he runs 30psi in all his boats with all bolt ons. I'm currently at about 23 psi, and it feels very close to perfect, but a slight bog off idle. It idles in the water, but rough, and after playing with the low speed screw a bit, I couldn't get it to clean up. So just kinda wondering if i should go lower or higher on the pop off.
    PWCToday.com Is My Home Away From Home timothy's Avatar
    Oct 2010
    florida yo
    They sure are gutless stock , but put a factory pipe on it and its a fun ski
    Aug 2012
    Brick, NJ
    Yeah I got this all dialed in now...got a factory pipe on there, and with this carb and the flywheel, this thing rips pretty good!
