    Resident Guru mandriva's Avatar
    Sep 2009
    montreal,quebec
    do you still buiness ?
    Hi, chris,do you still in buiness? I have send a mail, no answer...I want buy a jet kit for my xpl 951 twins pipe(flame arrestor,choke removed )she run great with recommandation factory pipe,but i know you have better jetting?
    Thank you chris,, let me know?
    Rossier 7250 rpm
    110 mid pipe/200 stinger
    Head 43cc/45 squish
    Strak swirl 17/22
    Top Dog sea-one's Avatar
    Aug 2011
    Dallas tx
    Re: do you still buiness ?
    You,ll need larger needle and seats too boss
    2004 Rxp Stock Motor with other light mods
    1996 Xp Resurrected july 2014/SOLD 2016
    1991 Kawi 750cc Big pin Twin Carb Sport Cruiser Custom (Resurrected Feb 2015 completed June 2015)
    2000 XP Saved Spring 2016- Resurrected July 2016 as new
    2002 Seadoo ISLANDIA/Sold
    CANDoo Pro system
    Feb 2004
    Glendora, California
    If it runs great, I wouldn't look to change too much. But, yes, Factory Pipe often recommended using the smallest needle and seat possible. From our experience that puts motors right on the edge of being too lean. We typically use larger needle and seats for everything that has an aftermarket set of flame arresters or more.
    Sep 2009
    montreal,quebec
    because i wiil put EGT...but yes ,she run great! I am curious,can i put ecwi on chamber or head pipe with twins pipe? Without ecwi the Acceleration is amazin,but i am curious......i run with main 177 on stinger
    Rossier 7250 rpm
    Head 43cc/45 squish
    Strak swirl 17/22
    Feb 2004
    The only place we saw an advantage with ECWI on the 951 twin pipes was by adding water to the stingers at max rpms. So a fixed jet to the stingers at idle, low, and mid rpms. Like say 130 main jet in each stinger. Then, use another waterline in to each stinger with a much larger jet (say a 200 main jet) that only turns on (open) at around 200 rpms below your max. The way you do this is with a water controller connected to 2 solenoids (1 per stinger) that turns ON and stays ON from that rpm and up. And you use a T or a Y and install the appropriate jets in there before the water gets to the stinger fittings. So the smaller jets are always flowing water and the large jets get opened up and also flow water at the peak of the power band.
    Less water in the stingers means more bottom and mid-range power. More water to the stingers right before and at max rpms means more peak horsepower.
    Sep 2009
    montreal,quebec
    okay, thank you! But with big jet on stinger wil raise chance for deto? If yes?what is the max size i can put on stinger.... these pipe is very Really incredible, really a big power gains...I am impressed of the factory pipe hose 951 and 787
    Rossier 7250 rpm
    Head 43cc/45 squish
    Strak swirl 17/22
    Feb 2004
    Absolutely more water in the pipe stinger(s) can cause detonation! But most things that help increase horsepower will cause problems if you go too far. I don't have a max size I can tell you. Too many variables to know what your combination will work with safely. Always make small adjustments and pull the RAVEs out to look at the tops of the pistons if you are worried about detonation.
