Finally After Years It's almost ready
Results 1 to 9 of 9
    PWCToday.com Is My Home Away From Home cameron da river rat's Avatar
    Jul 2003
    In the Garage.....
    theres been a ton of crap happen torwards the end of the build that i had to push this to the side but finally got it all going this weekend.
    still have not solved a few issues like electrical box that the msd cdi and coil and now i can't close the lid, i guess they are too big.
    another is cooling routing with the riva red, not sure if i have it right or not. i'll send some engine pics later, im still embarrassed of how it looks ....lol..
    i can't get good pics of it close up but it looks way better than in the photos
    aka "Cameron Da River Rat"
    (jetskianist~addicionist~modificationist)
    www.jetski247.webs.com
    92 550sx 650 conversion sweet.........
    94 fx1 (under modification)
    2 X2's (under modification) one for the kiddo
    98 spx stock/fpp spec2 (broke)
    03 genesis i (huge pos)
    95 f150 tonka toy
    04 suby sti
    Michigan
    Re: Finally After Years It's almost ready
    Subscribed!! Looks like a nice ski. I'm in the process of building my second FX1. Post some detailed pictures under the hood. I'm sure you will get some good iformation.
    Jul 2003
    In the Garage.....
    DSC00333.JPGDSC00334.JPGDSC00335.JPGDSC00336.JPGDSC00338.JPGDSC00339.JPGDSC00340.JPGDSC00341.JPG
    don't laugh, its my worst work i promise, i just slapped everything together to see if it actually worked and ran
    i did the foax carbon fiber with silver and black and some anti slip mat, doesn't look bad for a first time paint job but it definately has its flaws.....lol
    this ski was a basket case when i got it
    i put the wet jet 46mm carb and westcoast f/a that i had laying around, stock reeds, bored .50 over with the riva pipe that i assume use to be red that someone powder coated purple
    pops right off, no primer needed, even after sitting for a few days, can't remember what jets/pop off i put in
    problems:
    cant get ebox lid to bolt down properly, coil is too big w/o modifying the lid
    cooling routing, i see lots of different chematics online but not sure how this one went/goes
    water is not warm enough to go rip it a new one
    i was going to do the big pump as well as some other stuff but just got tired of always having a work in progress and just want to ride again.....
    95 f150 tonka toy
    04 suby sti
    Michigan
    I'm looking at the thread on my my phone.. Can't really view pictures well. I'm considering the Riva pipe on my current build. I have a Factory B Pipe on my other FX and my SJ/SN. Are you running an OEM e box with an MSD ignition enhancer? That is what I have on my skis.. Works great and fits cleanly in the stock box.
    Jul 2003
    In the Garage.....
    yes, running the msd enhancer and msd coil, the coil is the problem.
    it seems that the hull is drilled for two seperate spots for the ebox to me mounted to? is this normal or just how this came?
    the ski came with the pipe, sounds great, throttle is very snappy!! can't waint to bury one in this thing and see what she's got.
    i think motoman gave me some fx1 suggestions long ago but can't remember what they were. this thing WILL be ridden this summer, no matter what.
    added a few things today, got rid of the siphon bilge and added a front bumper, nyogel'd all my electrical connectors, added a 650gpm bilge pump, bilge pump bracket and waterproof handlebar switch, capped the water pisser which im sure will piss me off......lol......found out my primer does not work but so far have not needed it, going to look over some water routing tonight and see if i can figure out where things need to be, i mean i know where and how almost any and all two stroke exhaust's are plumbed but not this.
    im assuming water enters in through the manifold, travels up through the top of the cylinders, out the top of the cylinder in your choice of 3 spots, then goes to the head pipe, bottom of head pipe to stinger, other head outlet split or hull exit???
    this head has 3 exits, one is plugged since the exhaust bracket pretty much blocks it, the other is a larger one and one is very tiny. ive never seen the tiny one.
    95 f150 tonka toy
    04 suby sti
    Mar 2005
    Santa Barbara, Ca.
    Hey Cameron ... Glad to see you back!
    Jul 2003
    In the Garage.....
    You too Bruce! Long time no read.....lol
    Now that the little ones are big enough to take to the lake (4 kids now) i'm going to be riding this as much as I can as well as my new VXR!!
    95 f150 tonka toy
    04 suby sti
    Jul 2003
    In the Garage.....
    just as an update, ski runs great, going to take the riva ride plate off and install a carbon fiber one and see if i can get it to stop the rear from wanting to slide out, also thinking about installing some tubbies....any thoughts? i can barely hang on this thing at wot....went up against my buddies 2016 superjet (all stock) and just left him like he was on a 550....lol...the throttle response with all the mods is pretty nice......i can't imagine a 951 in one of these...
    95 f150 tonka toy
    04 suby sti
    Mar 2007
    Is Everything!
    Cam where are you at?
    Whatever became of your build?
