Seadoo X4 1100 conversion build/resto - Page 2
Page 2 of 53 FirstFirst 12341252 ... LastLast
Results 11 to 20 of 525
    May 2002
    Blasterville, USA
    Re: Seadoo X4 1100 conversion build/resto
    97 SPX didn't come with the spacer, so if you go that route, you won't be able to use the set back pump from the 95. The other option is to have skat build you one, but they are expensive!
    AS for the porting, no matter who does it, make sure they know Kawis, especially 1100s, because you can't go in there and port like a normal Yamaha cylinder or you run the risk of cutting into the water jacket. If you have any questions, PM me.
    SM
    Proud Member of TEAM TFP!
    JAM Racing
    Judge Motorsports
    www.hotproductsusa.com
    www.optimaracing.com
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ProWatercraftracing.com
    www.ipdjetskigraphics.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    Yeah, Skat is out. What do you mean about the spacer on the SPX? It's true they didn't use a setback pump on the SPX but why would it matter. All it means is the SPX driveshaft is a hair bit shorter than the 95 XP driveshaft; but seeing as I'm custom making one, I'd just have the Kawi shaft cut a bit longer to offset the difference. Am I missing something here?
    SM
    Thanks, I'll probably pick your brain a bit more regarding this going forward.
    May 2002
    Blasterville, USA
    That set back kit on the 95 is like 4 inches, longer than stock, I was assuming you were just cutting the end off the shaft and having it done, but if you are making one, then yes, any of the XP/SPX shafts will work.
    SM
    JAM Racing
    Judge Motorsports
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    SM
    It's a shade over 5-1/2" longer.
    What do you mean by cutting the end off the shaft and having it done? That's essentially what I will be doing.
    Take a look at the pic of the driveshaft I posted yesterday and let me know if that looks correct. I am cutting the end off a 787 driveshaft as well as the Kawi shaft and mating them together with a coupler. Seems pretty straight forward unless I'm missing something?
    Dp.
    Here's the pic.
    May 2002
    Blasterville, USA
    Yes, that will work, I just don't like the weld point being that far toward the middle of the shaft with the extra 5.5 inches of the set back. But, it could be fine, no way to know without doing it and testing it. Triples make a lot of torque.
    SM
    JAM Racing
    Judge Motorsports
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    Thanks Scottie. In your experience, would you say the advantages of the setback outweigh the possible negatives from the longer shaft?
    I certainly don't have to go with the setback but like some of the benefits it would provide.
    May 2002
    Blasterville, USA
    Honestly, I think going the set back route is a waste because eventually you will end up going to a bigger pump, either a skat 148 or a xpl conversion pump. I know you said you didn't want to do the work, but once you get this thing running I think you are going to quickly come to understand that the 140 is the one part holding you back. My buddy Jeff's 1100 x4 with the 140 pump and set back runs good, but when you ride Justin's with the big 150 XPL pump, it is crazy how much more power is put to the water. Remember, the 1100s never came with anything less than a 148 from Kawi. Even good 800 kawis are held back with the 140mm stock sxr pump and the triple has twice the torque of an 800.
    SM
    JAM Racing
    Judge Motorsports
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    I'm sure you're right Scottie.
    I'll probably start with the setback and then when I upgrade pumps down the road I can just cut the Kawi shaft a bit shorter and re-thread. I'm hoping the setback paired with the big hub pump will play nicely for now.
    That being said; maybe I should start perusing threads on a 155 install. I do have 2 months to get it done.
