Results 1 to 10 of 11
    PWCToday Regular watersled's Avatar
    Dawsonville, GA
    Re-pitching an impeller
    I'm currently running a swirl 12/17 but I don't think I am getting the RPM's and speed out of my ski. My set up is:
    62t/61x
    dual 38's jetted 135 main, 70 pilot, stock needle and seat, stock spring
    Factory limited pipe
    rear waterbox and rear outlet
    Flow control valve
    dual cooling
    MSD enhancer
    With this setup I was only pulling 6550 RPM and 48-49 MPH. I'd like to just re-pitch the impeller I have but what would I want to pitch it to for racing? Also, feel free to critique my current set up as well. Thanks!
    Sport Stock and Sport GP #346
    -IPD Graphics -Lucas Oil
    -Riva Racing -Jet Dynamics
    -Extreem Throttle -Jettrim
    Re: Re-pitching an impeller
    is jetting spot on? how fresh are your rings? whats your squish band at and whats your compression? thats a low RPM for having a pipe on it.
    PM scotty mac or he will probably see it here soon enough.
    1994 1100 SJ - Dead
    1996 spec hx
    PWCToday.com Is My Home Away From Home Wet Wolf's Avatar
    Nov 2001
    Spokane, WA
    Yeah, somethings wrong, It should be able to spin that prop to the sky with no problem.
    Bruce Wolford (509) 280-5444 - Pump Performance
    http://www.wetwolf.com
    PWCToday.com Is My Home Away From Home Rod Peters's Avatar
    Jul 2010
    No. Colorado
    Contact Impros, I am sure they can help you out www impros.com/store or 515 N Smith Ave Ste 102, Corona, CA 92880 (951) 737-2900
    Apr 2006
    Las Vegas
    49 seems kinda high for such low RPM. Im wondering if your pitch is too high, or higher than you think.
    Dawsonville, GA
    It's supposedly a 12/17 but never checked it myself. As far as the jetting goes, it's close, I've only messed with it for about an hour on the water but if I turned in the main, the RPM would fall off. If I turned it out the RPM wouldn't reach over 6500.
    Dawsonville, GA
    I'm running the stock head right now, roughly 145/145 compression.
    PWCToday Guru HXLOCO's Avatar
    May 2007
    CHINO CA
    Quote Originally Posted by tshank123 View Post
    Right on Tim 49 my blaster with more stuff than you have barely turns 48 49 mph at 7250 rpm but the acceleration is decent it could be r the prop too tall or maybe the pipe too cold
    Apr 2006
    Las Vegas
    Quote Originally Posted by HXLOCO View Post
    Hoping to get on the line with you at some point this season. I'm in the middle of a sport spec blaster build. I want to have fun in sport again.
    Apr 2006
    Las Vegas
    Quote Originally Posted by watersled View Post
    62t/61x
    Flow control valve
    dual cooling
    MSD enhancer
    With what you have I wouldn't expect much more out of it. Stock head, stock 38s, 61x cylinder with a limited chamber, those are your limiting factors here. Still its not bad top speed wise, I just wonder how the acceleration out of corners is.
