Results 11 to 20 of 21
Thread: 1998 ts1000r
    Top Dog sea-one's Avatar
    Aug 2011
    Dallas tx
    Re: 1998 ts1000r
    Of course not,Work the choke a bit during this and see if it improves. If so , its lean from probably carbs dirty jets. Check the spark plugs for a chocolate brown and wet oily threads.
    2004 Rxp Stock Motor with other light mods
    1996 Xp Resurrected july 2014/SOLD 2016
    1991 Kawi 750cc Big pin Twin Carb Sport Cruiser Custom (Resurrected Feb 2015 completed June 2015)
    2000 XP Saved Spring 2016- Resurrected July 2016 as new
    2002 Seadoo ISLANDIA/Sold
    CANDoo Pro system
    Cottage Grove, MN
    Re: 1998 ts1000r
    Nice find man. This makes me sad personally as I just lost mine two weeks ago on a jacked up trade. I miss mine already. These are beautiful boats and you will enjoy them more than any ski built in the last 15+ years. I personally convert every ski I own to premix but know alot of people that dont. Personal opinion if you trust the pump or not. No clue about Polaris, been a Shark fan boy since day one have never ridden anything else. Mine had a slight bog right about where yours takes off. A very slight mid range bog was typical of these skis. Should not have a low end bog though. Clean the carbs and replace all your fuel filters. If it persists rebuild your fuel pump.
    Own:
    99' TS770R
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    94' Montego (my first) sold
    95' Daytona sold
    95' Daytona parted out
    95' Barracuda sold
    96' Montego sold
    96' Monte Carlo 900 sold
    PWCToday Regular ultra560's Avatar
    Feb 2015
    Dallas, TX
    Re: 1998 ts1000r
    Man honestly, i would love to feel the true performance of this ski. I converted it over to premix last year, installed all new tygon fuel lines. I havent opened the carbs, or fuel yet so im sure they Will need some attention. I have secon set of carbs im gona throw on and see if there is a difference. Plan to rebiuld one of the sets. Where can i find genuine mikuni rebiuld kits for the carbs, and fuel pump?
    Feb 2015
    Dallas, TX
    Re: 1998 ts1000r
    Allright pulled the carbs this morning to get an idea. Noticed when it runs on the center carb fuel keeps running out of the jets.. again no balls till 3500 and up. Pulled the diaphragm cover on the pto carb and found some debris, and rust. Think ot would be better to just find a good set of carbs.
    PA
    Re: 1998 ts1000r
    OK, so there was some water intrusion. I think you'd be better off going through your own carbs first. I can see you paying some severe cash for a set of trips. You'd likely have to rebuild whatever you bought anyway. Remember, you're buying 19 year old equipment.
    Feb 2015
    Dallas, TX
    Re: 1998 ts1000r
    You are right! Where can i find the correct mikuni carb, and fuel pump rebiuld kits? All the once ive found are cheap knockoffs or for different mikuni carbs
    Feb 2015
    Dallas, TX
    Re: 1998 ts1000r
    alright did some searching and think I'm going this route.
    for fuel pump im going to pick up the mikuni triple outlet pump.
    https://www.atlanticjetsport.com/ind..._detail&p=1081
    and i fount these rebuild kits, i believe 1000cc sharks 40mm I series carbs
    https://www.powersportsuperstore.com...kbn3844spr.htm
    whats you guys thoughts on replacing the needle and seats as well?
    PA
    Re: 1998 ts1000r
    With the unknown age of the parts, do yourself a favor and go 100%. You'll hate yourself if you have to do it twice.
    Feb 2015
    Dallas, TX
    Re: 1998 ts1000r
    Yeah so true. I ordered all the parts, all new fuel hose, filters ect. Will keep you guys posted.
    Feb 2015
    Dallas, TX
    Re: 1998 ts1000r
    Update!
    Finnaly got around to redoing the carbs.. center, and mag carb was completely rusted up. Diaphragms were torn ect. Took it out Friday mornin. Was amazed how well it runs, no midrange stumble! Tach just pulls hard and fast to 7100rpms! Cruising aroud at 3k rpms if you lay into it, the handle burs just pulls out of your hands!
    This thing is a beast! ��
