Results 11 to 20 of 32
    PWCToday Newbie knewton's Avatar
    Sep 2015
    Ottawa ks
    Re: 87 650sx no ststart.
    Sounds good, what's the plan?
    Sep 2015
    Ottawa ks
    I'm in, what's the plan?
    Sep 2015
    Ottawa ks
    Oops though the first on didn't go through.
    Sep 2015
    Ottawa ks
    I rechecked the compression today. Front cylinder 135, rear 140. I also tried some ngk iridium plugs with no luck.
    Frequent Poster Sxsixfitty's Avatar
    Nov 2014
    Michigan
    I am leaning toward an electrical issue at this point. You're compression seems to be ok although the difference between cylinders is borderline. If it won't even fire on starting fluid maybe you have weak spark. Probably have to check your electrical system with an ohm meter.
    Jul 2006
    Kansas
    knewton i am going to pm ya. Maybe we can meet up this weekend? Waiting on my battery to charge so I can recheck mine.
    what carb do you have.
    1995 Tigershark Daytona--Sold!!
    2001 Seadoo GTI--Sold!!
    1999 Seadoo GTX Limited--sold did 58mph
    1999 Yam GP1200--Sold and missed!! 60mph..
    1985 KAW JS550--Sold!!
    1989 KAW 650sx--
    Sep 2015
    Ottawa ks
    It's a Keihin CDK II 38, choke plate removed for primer. The exhaust pipe is westcoast with stock water box. Block off plates for the purge valve & oil injection.
    Let me check what plans my wife may have for the weekend.
    Feb 2005
    Georgia
    I'm having what seems to be the same problem on my 88 650SX. I have tried everything I can think of but I cannot get this thing to start. I wish some one who has had this same problem and repaired it would come forward.
    Jul 2006
    Kansas
    Evening guys, I drove down to see Knewton, Figured it would be worth a shot to help a bud out. Strangest thing he has 150psi compression both cylinders with my tester, the spark does seem a bit weaker than mine. Using his primer or some starter fluid, it will not even try to kick. Checked to make sure cables are connected right. We checked to make sure exhaust is pushing air and not plugged on the side of the ski. I checked the TDC with the timing mark and it is right on. We tried to measure the cdi, however pretty much none of the readings match the manual.
    secondary plug-plug----16.8k ,, he has a spare one that measures 28k(original he took off)
    Charger yellow-yellow= 2 ohms
    exciter=320
    I came home and checked mine today..
    CDI secondary= 7.39k
    charger=2.3
    exciter=313
    I could not get any of the other measurements on the cdi to match the table either.
    1989 KAW 650sx--
    Jul 2006
    Kansas
    Does anyone know if those reading in the manual are realistic to get? We are using digital voltmeters.
