Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    PWCToday Newbie knewton's Avatar
    Sep 2015
    Ottawa ks
    87 650sx no ststart.
    1987 Kawasaki 650sx won't start. At first no spark, now everything replaced has spark but still doesn't start. Turns over fine. Here is what I have tried so far since October . Compression 135psi, engine rebuilt 2005. New battery, plugs, cdi coil, starter relay, voltage regulator. Stator rebuilt (Jetski Solutions ), fresh gas, extra ground wires added, start/stop switch checked, flywheel magnates checked, all wires from bat to starter checked. its run great with no problems until October. I usually start it every other week until no start in October. I'm out of ideas. Thanks in advance.
    Frequent Poster Sxsixfitty's Avatar
    Nov 2014
    Michigan
    Re: 87 650sx no ststart.
    I would check your fuel pump. I think yours has the remote fuel pump. Sometimes they dry out and lose prime. Will it fire if you give it a shot of starting fluid?
    Sep 2015
    Ottawa ks
    Thank you, I have tried starting fluid with no luck. Mine has a keihin cdk II 38 with the pump on the carb. I pulled the carb and reed cages today. Reeds ok, cleaned & checked internals on carb. Nothing found in carb(dirt). Will Finnish and try again tomorrow.
    Sep 2015
    Ottawa ks
    I finished putting the carb back on and still no luck.
    Nov 2014
    Michigan
    If you have good spark and the plugs are dry it almost has to fire with starting fluid. My other thought , did you just recently check compression or was that awhile ago?
    PWCToday.com Is My Home Away From Home Rod Peters's Avatar
    Jul 2010
    No. Colorado
    Agreed ^^^^^^ compression is below boarder line, for altitude in Kansas, thats like 5500 plus feet compression, might want to recheck.
    Sep 2015
    Ottawa ks
    It was dec. I will recheck Monday.
    Nov 2014
    Michigan
    Other than that maybe timing? If you don't already have one I would recommend a Clymer service manual. They have a good diagnostics section. Hope you get er going soon. Keep us posted.
    Sep 2015
    Ottawa ks
    I pulled the flywheel a second time to check the key and timing mark. I have Clymer and the original service manuals (a friend was the original owner). Normally easy to fix. This has been a real head scratcher. I see spark but don't know if I consider it strong.
    Jul 2006
    Kansas
    Hi knewton! I am in Olathe, ks. I have an 89. I am having to go through mine as well for bog/power. Lets get your spark fixed!
    1995 Tigershark Daytona--Sold!!
    2001 Seadoo GTI--Sold!!
    1999 Seadoo GTX Limited--sold did 58mph
    1999 Yam GP1200--Sold and missed!! 60mph..
    1985 KAW JS550--Sold!!
    1989 KAW 650sx--
