550 Crank Question
Results 1 to 6 of 6
    PWCToday Regular Groundfox98's Avatar
    Jul 2015
    Orange
    550 Crank Question
    On my 550 that I bought I noticed it was missing the plate on the pump side of the crank that has four bolts and bolts to the side of the case. I haven't been able to get the motor started and was wondering if t was absolutely necessary to have that piece on or if I can live without it and move on to my next issue.
    Dec 2014
    Lancaster
    2
    Re: 550 Crank Question
    Post pic of area in question to see if it matters, you probably do not have a full circle bottom end,
    Jul 2015
    Orange
    I don't have a picture of my exact motor at the moment, I can take one when j get home I a Few hours. But
    It's the part between the crank rotor and the case
    Jul 2015
    Orange
    My case has the four holes but doesn't have the plate that my other ski has.
    Dec 2014
    Lancaster
    2
    A pic will verify, if it has a bolt holding coupler on its a full circle bottom end, and unless modified would require seal carrier
    Jul 2015
    Orange
    So could that be why I've been so unsuccessful at getting her started? It has 135/135 compression and a primer. It will turn over and sputter but it won't start.
