Kawasaki 650SX Will Not Start
    Feb 2005
    Georgia
    1988 Kawasaki 650SX, I have rebuilt the stator that was damaged by rivits breaking on the flywheel. I installed another flywheel and the ski will not start. I then figured the CDI was potentially bad so I ordered a new CDI from SBT , installed the CDI along with a rectifier from SBT but still no start. The spark plugs are sparking and the ski has 135-140 compression and I also have new reeds installed. Is there anything else that can be my problem I can't figure this one out. The ski ran great untill the rivits came out of the flywheel and damaged the stator. What else can I check?
    Aug 2010
    Australia
    Re: Kawasaki 650SX Will Not Start
    spark in the correct place , fuel , compression to make a 2 stroke run >>> ,check your timing ,crank may have slipped ..
    modded X2 650
    900 powered custom 650 sx .
    Feb 2005
    Georgia
    i checked the timing it is ok. I got the ski to start and it ran fine but once I shut it down it hasn't restarted since. I checked all the connections could find nothing. I can't figure this one out.
