Triple in a 550 - Page 2
Page 2 of 25 FirstFirst 123412 ... LastLast
Results 11 to 20 of 247
Thread: Triple in a 550
    Top Dog Rompn's Avatar
    Aug 2004
    La Crescenta, CA
    Re: Triple in a 550
    Cool build. With some modding a triple fits, floats and works. Not to many out there though. Subscribing...
    Patrick Goldsworthy
    Region 1 / Vintage Ski / #28
    Chris "Fish" Fischetti & Victor "The Slasher" Sheldon
    PWCToday.com Is My Home Away From Home Rod Peters's Avatar
    Jul 2010
    No. Colorado
    Re: Triple in a 550
    This is crazy, but I like it, FYI the hull gets unstable at about 40 mph, however I am sub'ed to see how the extra weight is a plus or works against the design of the hull. MORE PICS please. Might recommend tubbies and "Fish Sticks" (see www.watcom.com) for the fish sticks.
    Resident Guru 800amsoil4u's Avatar
    Jun 2005
    Morgan Hill, CA
    Re: Triple in a 550
    Nice build. Cant wait to see it when it is done. Subscribed.
    Save up to 25% by becoming an AMSOIL Preferred Customer
    Prices listed are Retail. E-mail or Call me for a price quote.
    http://www.TrySyntheticOil.com
    Kevin Stubaus AMSOIL Dealer for over 25 years
    TrySyntheticOil@Yahoo.com
    1-800-AMSOIL-4U (267-6454)
    Yamaha 2001 GP1200R W/RXPX Engine in it
    Polaris 785 Pro Super Stock
    2000 Polaris Pro 1200 Super Stock
    Kawi 550 Mod, Stroker Reed Motor
    PWCToday.com Is My Home Away From Home WaveRunner Eagle's Avatar
    Aug 2008
    Gainesville, FL
    Re: Triple in a 550
    Quote Originally Posted by 123hi View Post
    As long as this thing is faster than Waverunner Eagleís build Iíll be happy hahaha
    I'm not sure if you mean your build will be completed quicker, or your ski will be faster.... I think you have a good shot at being right on both counts
    On the other hand....a factory pipe could probably make up a good part of that 10 h.p. difference....
    Skis:
    1986 X2
    1987 750 X2
    1990 SNSJ
    1994 WB1
    1995 VHP
    PWCToday.com Is My Home Away From Home Ragged Edge Racing's Avatar
    Dec 2004
    At D River
    Re: Triple in a 550
    Put some front sponsons on as that might help float it a bit better and add some stability. Get some Pro Watercraft, they should work well.
    Top Dog orangefinger's Avatar
    May 2006
    Reno,NV
    Re: Triple in a 550
    great build , keep us posted
    btw the floating part will change as soon as the exhaust is in....:0)
    94 Blaster "KAW 1100cc"
    650 SC
    Top Dog rhugo21's Avatar
    Jul 2010
    Santa Monica, CA
    Re: Triple in a 550
    You've inspired me! I've located a 900 Kawi for $300
    2017 SJ
    1988 550 w/PJS Viper 700
    Midwest Wave Warriors
    Mar 2005
    Santa Barbara, Ca.
    Re: Triple in a 550
    Here is a thread to my 1100-550 mockup. I moved on to other projects ...like the 1100 X2. After riding the X2, I gave up on the JS 1100 ... always afraid the X2 will sink and the JS would be worse! It will float much lower when you get done... believe me!
    http://www.pwctoday.com/showthread.php?t=395567
    However...
    The stripped pipe was real close to fitting with a small blister and and milled manifold
    Convert it to center-bleed for sure
    A late mode Superjet waterbox will strap right in and has the big diameter tubes ... side exit probably
    The electrics will fit in a plastic box easy like a JSS conversion
    A RCI 4 gallon dragster tank will probably fit right in there .. Put one in a 550 SX with a 701 FPP ... fit nice
    Good luck! I want a ride...
    Jun 2014
    Seattle
    Re: Triple in a 550
    Subbed. Sick build!
    78 JS440
    -Ocean Pro Finned Ride Plate
    -Westcoast Intake Grate
    -SCR Ported Cylinder
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    -Skat~Trak 16.5 SS Impeller
    PWCToday.com Is My Home Away From Home jetskijockey's Avatar
    Dec 2007
    Eau Claire, WI
    Re: Triple in a 550
    I have a 900 zxi pipe that has been cut down to fit into a 750sx with a 900/1100 engine. I don't think I will ever use it as I am saving to buy a Bullet hull. The bolt holes need to be retapped, payed $75 for it.
