Bullett gen2 x2
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: Bullett gen2 x2
    Top Dog octane114's Avatar
    Mar 2009
    charleston,sc
    Bullett gen2 x2
    It has been a long process but it's close to being finished.
    -2 bullett
    dasa 920cc ported by eric b.
    novi 48's
    boyesen intake
    advent d23 custom tune
    nynja exhaust, jetworks fcv, drilled oem w/b
    skat 145 2" setback pump tbm intake grate shreadmaster ride plate.
    it is what it is . it's all good
    Mar 2009
    charleston,sc
    Sep 2005
    AZ
    Re: Bullett gen2 x2
    Looks sweet!
    1992 Laser Jet F14 - Raced in 1992 World Finals.
    1992 550 SX - PJS Secret Weapon Big Bore, Kind of fast, LOL.
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust. 45 MPH, yee ha!
    1976 JS 400 - Pretty much just a shell. Sure want to restore this some day!
    Mar 2009
    charleston,sc
    Re: Bullett gen2 x2
    With engine mounts and op plate she weighs in at 131.7
    PWCToday.com Is My Home Away From Home Rod Peters's Avatar
    Jul 2010
    No. Colorado
    Re: Bullett gen2 x2
    Sub'ed I like
    Top Dog aggrovated's Avatar
    Frozen Tundra, MN
    Re: Bullett gen2 x2
    Yes, that Dasa is sweet! extra parts I see.... i'll be picking your brain on which ones you like and why.
    Frozen Tundra, MN
    Re: Bullett gen2 x2
    I have an OEM battery box gasket you can have.. I dont need it with mine as my battery open on the hull is wider, whereas on yours it will fit perfectly.... if you want it.
    Mar 2009
    charleston,sc
    Re: Bullett gen2 x2
    I filled my pump shoe, dressed the tunnel area and scuffed the bottom. I glued in the shoe before I filled it so I hung it so the epoxy wouldn't run out.IMG_20150610_194508198.jpgIMG_20150610_203844051.jpgIMG_20150606_203452108.jpgIMG_20150606_193707827.jpgIMG_20150610_193156838.jpg
    Frozen Tundra, MN
    Re: Bullett gen2 x2
    why did you fill the pump shoe? i've seen rubber pump shoe fillers for sale... why is it necessary to fill the pump shoe up?
