Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    I dream skis GabeH's Avatar
    Nov 2012
    North Carolina
    Re: SBT Very Bad Experience
    Quick plug: I put an SBT motor in a GP760 waaay back in aught-7, sold it to a friend in 2010, and it's still going strong today!
    Old timer's tale: Bought a SJ from fleabay, test rode it and it made water rainbows. Checked all the fuel lines, and the carb return went up into the pole for a vent and the tank vent line ended somewhere down near the midshaft, and I mean ended, it was open. Always double check other people's wrenching. "To ride jet skis is to fix jet skis" this pastime is not for the mechanically-challenged!
    Top Dog Cleatusjo's Avatar
    Aug 2014
    Wealthy family of a foreign diplomat in Washington D.C. buys a custom van at a dealership. They drive off happy and once they are on the beltway, the driver puts the " Auto pilot" as he called it (Cruise Control)on, gets up out of his seat, and joins the family in the back. They promptly smacked the jersey wall, and called a lawyer to sue the dealer for not explaining the term cruise control.
    Edit: One note: Thousands of lawyers graduate law school and the bar yearly, yet they NEVER retire. I have seen them use a walker to get into the court room. It takes creative precedents to keep them all fed.
    I put a SBT engine in a customers Seadoo, he continually left it floating in the water and sank it numerous times, even after years of abuse and multiple drownings it continues to run to this day.
    Oct 2011
    Mechanicville, NY
    My 06 FX Cruiser had a reman mr1 from SBT stuck in, 65 hours (3 seasons later) and it ate a cylinder and left some dings in the crank case.
    Jan 2012
    Georgia
    http://www.loctiteproducts.com/p/10/...r-Blue-242.htm
    + proper torque prevents things from falling off of skis AND motorcycles. Such a multi-use product!
    Aug 2014
    One last note on this. On a re-assembled, re-built engine aren't you supposed to re-torque the bolts after a few hours. I have dissasembled skis and have found many exhaust manis so loose, I didn't even have to use a wrench. You suck air here , you got a burnt piston.
    94' Kawi TS 650cc Coffman, R&D ex.mani ,44 Mik, 46mm intake, 10/18 Scat, 3 degree nylon trim ring, OP RT noz & plate, 160 psi. 40.4 MPH 160lb rider, full tank at 6500 RPM
    93' Kawi TS 650cc Coffman 750 ssxi pipe, chamber, stinger, SC box, Mariner head 180psi, Coffman 650 ex mani bored 48.6mm , Boysen reeds & stufs, bored intake, mik 44, B-printed pump w/ 9/17 Scat, 2 degree nylon trim ring, plate with w/ skegs and d-cut , OEM 83mm noz. Still tuning. Reeds & stuffs gotta go.
