900 vs 1100 cranks
Results 1 to 10 of 11
    PWCToday.com Is My Home Away From Home spitz15's Avatar
    Nov 2008
    Cleveland, Ohio
    900 vs 1100 cranks
    Are kawi 900 and 1100 cranks interchangeable..?
    Im addicted...
    Re: 900 vs 1100 cranks
    20mm wrist pin on 900 crankshafts, 22mm wrist pin on 1100 cranks
    Aug 2010
    Australia
    short answer NO ! ,they are 90% (give or take) different crank assembly !
    modded X2 650
    900 powered custom 650 sx .
    Nov 2008
    Cleveland, Ohio
    Quote Originally Posted by hyosung View Post
    Thank you.
    Im addicted...
    Feb 2002
    Vancouver, BC Canada
    This reminds me of a ZXi 1100 that I rebuilt for a customer. It was previously modified and had a 900 crankshaft with Yamaha pistons in it.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Aug 2010
    Australia
    how did that work out ? ,
    modded X2 650
    Feb 2002
    It worked out great. I didn't do the changes, I just rebuilt the engine for him. There were other mods too. I only presume whoever built the engine that way wanted a big bore and Yamaha pistons fit the Kawasaki 900 rods.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Aug 2010
    Australia
    Chester
    interesting !
    modded X2 650
    PWCToday Newbie barlosbhz's Avatar
    Aug 2015
    brazil
    2
    Hello! Guys, can I turn a 900 zxi engine into 1100? What would it take? Are the engine blocks the same?
    Top Dog
    Oct 2006
    under a ton of work
    cases and cylinders are different.
    with some work the 900 cases can be made to work,enlarge the transfer entrance ramps on upper case and relocate 1 dowel pin.lots of grinding but doable.
    cylinders will need new sleeves
