1988 wetjet barn find build thread. back to showroom condition - Page 3
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 101
    PWCToday.com Is My Home Away From Home jdpilot's Avatar
    Sep 2006
    New Hampshire
    Re: 1988 wetjet barn find build thread. back to showroom condition
    Prospect Mountain Powersports
    Altitude; 653
    Limited 87 650SX- 43.6
    Limited 93 X2- 45.1
    Limited 87 hull/86 internals X2- 43.7
    92 WR3- 37.0
    93 WR3 w/Shuttlecraft JetSport
    94 WB1- Limited
    09 superjet- stock 1 owner
    88 WetJet 432- stock 1 owner
    87 X2- stock 1 owner
    82 js440- stock 1 owner
    92 js440- stock 1 owner
    85 js550- stock 1 owner
    85 js440 super stock- Expert Womens Class
    85 js440- super stock- Region 8 Novice
    Sep 2006
    New Hampshire
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Sep 2006
    New Hampshire
    More wet jet goodies today. Was talking to my contact at the wet jet NOS warehouse. Cross referencing the accessory part numbers available back in the day. Stumbled on an add on rubber front bumper. I've never seen one on any of the few wet jets I've seen. Also never seen one on any online pix. Low and behold, there was only one left in the warehouse, so of course I snagged it. Also snagged the add on rear view mirror as well. This boat will not only be showroom, but will have all add on accessories that were available for it; bilge, glove box latch mod, fuel gauge, air intake update kit, oem mirror, oem storage cover, and the super rare front bumper. It's easy to snag add on parts when they are at rock bottom clear out prices.
    She may be awkward, slow, and a sit down. But, she's a piece of pwc history and now preserved with every add on, she'll be pretty special and unique.
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Sep 2006
    New Hampshire
    Factory optional bilge install today;
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    PWCToday Regular Madmaxt's Avatar
    Jul 2015
    Witch City, MA
    Quote Originally Posted by jdpilot View Post
    YIKES!
    I am assuming that is the same spot where the factory would have installed it?
    Sep 2006
    New Hampshire
    Quote Originally Posted by Madmaxt View Post
    YIKES!
    Correct. I'm not a big fan of marking up decals, but this is where it goes. The kiit s pretty nice. Comes with a paper template that shows you exactly where to drill. The reason it goes there is on the inside of the hull, look at yours when you can, there is black foam on each side. There's a horseshoe cut out in the upper corner of each side. The hole lines directly with that horseshoe cut out so you can get the pipe through it. It's a pretty slick set up. There are holes pre-drilled below the drive shaft for the pump itself. So easy bolt on there. Also the Wet jet has a wiring harness that is plug-and-play for the wiring on the pump. One additional hole needed to be drilled for the switch. And you'll notice on the dash of yours there's a place which says bilge on, off. Small hole there as well. Now that it's done it looks perfectly Factory. I'm fairly impressed. More pictures later this week
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Sep 2006
    New Hampshire
    This may be the last NOS add on bumper for the wet jet known to man. In the few pictures of wet jets out there, I've never seen one on one. This was the last one buried on a shelf in the warehouse in minnesota. Score!
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Sep 2006
    New Hampshire
    6 Jack nuts. Three were broke. New jack nuts installed (for tank mount point). Old tank gasket removed, NOS tank gasket installed.
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
  9. #29
    Sep 2006
    New Hampshire
    Ran into a snag 2 weeks ago. Tapered Fittings on top of tank were seized and spinning the pressed in inserts. Thought of modding the tank but found a NOS tank cheap. New tank installed, fuel line insulation per add on oem kit, new oem fuel filters, new gas gauge oem kit, and new clunk's and line in tank.
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
  10. #30
    Sep 2006
    New Hampshire
    Complete. Brappps nicely on the garden hose. Water test his week. ;
    https://youtu.be/55yu1QtY8tc
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
