Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
    Apr 2008
    lake havasu
    Re: 96 blaster sport spec build
    Keeping stock ignition . Getting a ADA head
    Enhancer will make it faster in both bottom and top. Head willnot help top end as much. What pipe are you gonna use
    1994 1100 SJ - Dead
    1996 spec hx
    Quote Originally Posted by 88kawi5fiddy View Post
    If you really knew what you are talking about people would think you know what you are talking about.
    You sure your name isint Cody ???
    Go watch the new star wars and complain about it
    1994 1100 SJ - Dead
    1996 spec hx
    Apr 2008
    lake havasu
    B mod pipe
    Sound good. Good luck!
    1994 1100 SJ - Dead
    1996 spec hx
    Apr 2006
    Las Vegas
    35cc ada domes are 185. Keep in mind if you run those domes, a pipe, and an ignition you might starting detonating the topend on pump gas. You might get away with it, you might not. I don't know anyone that runs spec blaster
    Im sure the OP appreciates the advice but he should know you're an HX guy. You say it right here that you dont even know anybody with a sport spec blaster, let alone have ever built one.
    Yes. 35 cc domes should be safe on pump gas as long as your following all the other rules. You cant advance the timing, deck the cylinder, or run any obtainable ignition besides an Enhancer.
    My advice was perfectly sound as you just reinforced. So get off that high horse crybaby.
    1994 1100 SJ - Dead
    1996 spec hx
  9. #29
    People that dont know what they are talking about shouldnt make posts like they do.
  10. #30
    Apr 2006
    Las Vegas
    Quote Originally Posted by cantski View Post
    B mod pipe
    Well I dont exactly agree with this one. If you're running 61X cylinder you will probably be better off with a limited chamber.
