Results 11 to 20 of 58
    Apr 2008
    lake havasu
    Re: 96 blaster sport spec build
    I was reading the rules .. So you can't run a removal dome heads ??
    blaster sport spec:
    run any wet pipe.
    run 62t cases.
    run any carbs.
    run any non-programmable ignition.
    run any aftermarket head. riva, protec, ADA,
    UMI steering.
    intake grate,
    ride plate,
    sponsons.
    1994 1100 SJ - Dead
    1996 spec hx
    Sep 2008
    City of Blasters
    Have to be pump gas. Only place they check your fuel is at the World Finals, but they can surprise you at the regional races.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Quote Originally Posted by Yamabooeey View Post
    Isn't it 95 octane?
    What does one run for fuel that's higher than 103 thats unleaded???
    1994 1100 SJ - Dead
    1996 spec hx
    Apr 2008
    lake havasu
    What are drop down domes. The rules say no drop down domes ???
    Sep 2008
    City of Blasters
    Quote Originally Posted by 88kawi5fiddy View Post
    Isn't it 95 octane?
    Don't know. Can't be leaded fuel.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Sep 2008
    City of Blasters
    Quote Originally Posted by cantski View Post
    I think those are domes that drop down into the cylinder.https://www.blowsion.com/kommander-8...-cylinder-dome
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    drop domes are/were very popular on 951 platforms. they allow extreme compression and dome design changes without modifying the cylinder. they can also accommodate flat top pistons in yamaha and seadoo applications without cutting the cylinder 2-3 millimeters. I had a riva 780 big bore dominator engine that was 5 mil shorter because of the flattop pistons. fast as #*$& and ran on 110.
    1994 1100 SJ - Dead
    1996 spec hx
    Apr 2008
    lake havasu
    so what domes are everone running 37s 35s... 190psi is max in the rules book
    35cc ada domes are 185. Keep in mind if you run those domes, a pipe, and an ignition you might starting detonating the topend on pump gas. You might get away with it, you might not. I don't know anyone that runs spec blaster
    1994 1100 SJ - Dead
    1996 spec hx
