    Frequent Poster superstock1986's Avatar
    Mar 2006
    Bay City Michigan
    sxr with 951 protecting the carbs from water
    Hi
    I have a sxr with a 951 in it. I was wondering if you make any type of snorkel kit for the carbs. They sit low in the hull and I want to protect them from water. Is there anyway to do this or do you have any suggestions as to what can be done?
    PWCToday.com Is My Home Away From Home Ragged Edge Racing's Avatar
    Dec 2004
    At D River
    Re: sxr with 951 protecting the carbs from water
    Put outerwares on the filters. It's will help shed the water. This is one downfall of this design. Also make sure the hose clamps are tight at the exhaust manifold right above them. I found out the hard way at high rpm mine wasn't.
    Mar 2006
    Bay City Michigan
    Thanks!! Will it lean out the carbs at all or can I just throw them on there and run it
    If anything they will richen it up a tad.
