My X-2 Gen2 build - Page 3
Page 3 of 30 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 298
    Jun 2014
    Seattle
    Re: My X-2 Gen2 build
    Sub'd too, sick build!
    78 JS440
    -Ocean Pro Finned Ride Plate
    -Westcoast Intake Grate
    -SCR Ported Cylinder
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    -Skat~Trak 16.5 SS Impeller
    Sin City USA
    Quote Originally Posted by aggrovated View Post
    Whoa! I'm super confused now...According to this http://www.impex-jp.com/catalogs/mar...2824_1943.html and multiple other sources, That long tube is exactly the same part used in the SXR.
    I understand the different exhaust outlet locations between the hulls of the x-2 and the sxr. But, I think the change is actually within the foam that is made especially for the jf800 (x-2)and not the js800 (sxr) as they are different.
    as in this example: http://www.impex-jp.com/catalogs/mar...2839_1943.html
    BTW: the bars only cost $105 dollars. super stoked when they arrived, because yeah, you cannot get those awesome grips otherwise.
    I don't see how the SXR tube can work in the X2...the difference in location will make the SXR tube too short...plus the X2 tube is factory molded with two bends in it...The IMPEX site doesn't show the last 4 numbers of the part number...but I am betting they are different. The difference in the foam for the X2 and the SXR is the small cutout for the hood air hose clearance (CIRCLED) and the angle of the exhaust tube in question, and there is one extra foam block in that assembly for the X2 model not shown in that drawing.
    Sin City USA
    This photo shows the extra foam block in the X2 model that is not shown in that drawing, (I covered the top of it in hydro turf to protect from the heat)
    So the Micro-K parts catalog shows the tube to be the exact number of the SXR tube. I am curious if it will be long enough
    Top Dog aggrovated's Avatar
    Frozen Tundra, MN
    Cross referencing the numbers on multiple sites shows the same part number for years 2005 and 2006 and it is for the SXR. Now I'm concerned.
    This site also has the same part # with complete reference #'s too:
    http://www.megazip.ru/zapchasti-dlya...0064/muffler-s
    Thanks for the pic... Here's mine.. tube measures 22" from the end of the foam. and of course there is a few more inches of leeway between the elbows too.
    I'm very curious too.. Thanks for pointing this out Jonny!
    Frozen Tundra, MN
    Jonny, Can you post a pic of this factory exhaust tube with the two bends in it please?
    Frozen Tundra, MN
    Here's a pick of the bars...
    Frozen Tundra, MN
    Here's a pic of the Handle Pole turning apparatus....That thick chrome washer in the middle cost me $70 bucks!
    Frozen Tundra, MN
    Here's a pick of the Hood Hinge.. after all that's said and done about this.. Maybe I should've purchased the Rad Dudes Hinge instead.
  9. #29
    Frozen Tundra, MN
    Here's a pic of the choke and gas nobs. Trinity doesn't mold spaces for these nobs, but there is room on the hull (in the same place) for them.
    I wonder if any of you guys actually use them?
  10. #30
    Sin City USA
    I cant post a pic right now, Charles has the tube he was going to use it for his GTX2 build, but it is the same shape as this replacement tube:
