If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
$$$$PARTING OUT BOTH $$$$ 88 440new 550 reed engine, PJS case, 44mm Intake, LS Exh maifold, westcoast pipe, 46 mikuni w primer, wiseco 76.5mm pistions, K&N filter, bad bones reeds, 440+550 pump. Mariner ext ride plate w fins and intake. 89 650sxfully rebuilt engine, west coast exh, Keihin 42mm w primer, milled +o-ringed head, scat trak imp, Ocean Pro ride plate, K&N filter, new paint+pads
what is the impeller for you have listed? is it new or used?
Comment
