93 Kawi. TS Build - Page 11
Page 11 of 11 FirstFirst ... 91011
Results 101 to 108 of 108
  1. #101
    Aug 2014
    Re: 93 Kawi. TS Build
    Stuffed 2 more noodles below the water line, total 7. intake, Mik. adapter, yamaha throttle plate bored 46mm , W.C. exhaust mani, 650/750 adapter, pipe bored to 48.6mm.
    Boysen Reeds and Stuffers.
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
  2. #102
    Aug 2014
    Build line-up
    1993 650cc engine, 180/180 comp.
    K&N high flo flame arrester
    Mikuni 44mm silver performance carb 140/120, black spring, 2.0 N/S
    Yamaha 650/701 throttle plate bored to 46mm
    Custom Keihin to Mikuni adapter bored to 46mm
    OEM intake bore to 46mm
    Boysen reeds and stuffers
    Mariner 29cc head
    .008 OEM head gasket
    Westcoast 650 Dual Cool exhaust manifold bored to 48.6mm
    Custom 3 bolt mani. to 4 bolt pipe adapter bored 48.6mm
    Coffmans 750 SSXI pipe, chamber, cut and modified for TS 49mm bore on pipe
    HPS couplers and band clamps for pipe, chamber, and stinger
    SC waterbox
    Blueprinted and ported 650 pump w/ Dual cooling lines and polished OEM cone
    9/17 Skat Trak 75R swirl
    Seadoo steering cable rubber wipers
    OEM grate re-machined with crossbar only remaining
    OEM re-machined ride plate W/ added skegs and a D-cut
    2* pump nozzle trim ring
    Tiny Tach
    Watcon primer
    Whitetail Machine, Billet finger throttle, bow/stern eyes, bilge outlet, bypass pissers
    Atwood 500 GPH Bilge pump
    Hot Products Bilge pump switch
    Billet Bilge pump switch bar mount ( Thanx Jonny X-2 )
    Atlantic wire covers
    25ft. Harbor freight rubber hose
    Some A/M aluminum bar
    F/X Kawasaki bar pad
    PJS Grips
    OEM starter, bendix, flywheel and stator
    320 CCA AGM battery
    NSK sparkers
    A bunch of pool noddles stuffed below the water line
    Hoseman purple, blue and neon fuel/vac lines
    Bosch fuel filters
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
  3. #103
    Aug 2014
    Damn .. forgot to mention the black and green tow loops purchased from a member.
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
  4. #104
    Aug 2014
    First ride out Thursday. Idle is smooth. Steady "lumpy" interupted slow bottom response, pick-up in Mid, tops out at 4300 then falls on it's face. 180 comp. It's a 44M jetted 140 H , 120 L, 2.0. It's a silver performance carb. Has orifrice work done. I'm going to back off to a factory 650/701 carb ( 135/115/1.5 ). My 94 screams at 160 psi, and you can mash the throttle from idle. This ski has 20 lbs more psi. and 2mm more exhaust. Might remove the Reed Stuffers. Any Thoughts as I won't return to the ski until the 11th ?
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
  5. #105
    Aug 2014
    ttt
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
  6. #106
    Aug 2014
    Re-installed a factory 701 Mikuni with new 135H 115L 1.5 N/S. Going to due some back yard tuning before I take it to the ramp. Started a bathroom remodel in August and lost the last month with the ski. I might have to remove the reed stuffers if tuning and smoothness is a problem.
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
  7. #107
    Aug 2014
    Just an update... Might visit a friend in Florida. I'll drag the skis down and pull the stuffers out and the reeds out and start with a 92' kawi. OEM set. Will have a new set of kawi 650 boysen reeds and stuffers for sale. 60.00 shipped. Group K swears by the oem 92' reeds.
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
  8. #108
    Aug 2014
    Pulled the stuffers , left the 2 stage Boysen reeds. They were great on the low end, sucked past 4500 rpm. If the reeds are untuneable throughout the rpm range, I have a set of mint 92 Kawi reeds I know will work. Might have a set of 2 stage Boysens with the cages for sale.
    These Kawi. reeds looked like this right out of the ski. Haven't touched them.
