750SX re-homing, pic heavy - Page 8
Page 8 of 8 FirstFirst ... 678
Results 71 to 73 of 73
  1. #71
    Jun 2016
    CT
    Re: 750SX re-homing, pic heavy
    Quote Originally Posted by scottw090 View Post
    Here is a reverse order process of getting the spring IN THE POLE. It was not fun. This was the first time I needed a cutting a torch and a BFH on this ski project. This spring is now a permanent member of the pole! I tried to follow some pictures of other guy's work and ended up cutting a box out that was fairly off - by around 3/8 inch. Hence the correction cuts to allow clearance to get the spring in.
    Attachment 513616Attachment 513617Attachment 513618Attachment 513619Attachment 513620Attachment 513621
    Sucks that I nicked up the Powder coat - it was not my best work. Honestly this bit was quite frustrating. The passages for the cables do not line up well. I foresee premature failure due to over stressing where the cables will flex. I don't see a solution either so i guess that's what I am gonna run. My Brother's ski has an AC pole and it uses the stock cable management hardware- so far i have to recommend that over this PLD just because the cables seem to run a much more smooth line into the hull.
    Next up... bilges and waterbox, maybe the fuel tank + cables
    Question for ya, how did you make a cushion for the top of the PLD pole? Looks nice. I have the same pole without a cushion. I also cut a hole in the base to slip the spring in there and enlarged the ports for the cables. The initial ports cut my steering cable, had to replace it.
  2. #72
    Frequent Poster vegasphotog's Avatar
    Apr 2019
    Vegas, Baby!
    This was an amazing thread....way beyond my comprehension....but, quite inspiring...
  3. #73
    Jul 2015
    Huntsville AL
    Quote Originally Posted by supergoldy1 View Post
    The chinpad is fiberglass. Someone was making them for this pole in the past. when i bought thepole, it came with it. However i did recover it.
