97 slt 780 4000 rpm?
    Oct 2015
    Saskatoon
    Hello I have 97 slt 780 and it's only goes to around 4000rpm ..Any ideas what I should be looking for ...my screen flashes on and off and works sometimes ..it just started doing this thx..machine is all stock to.
    Jul 2011
    Peoria, IL
    Re: 97 slt 780 4000 rpm?
    voltage regulator
    I've repaired a couple Polaris skis with bad stators that would do that. You've checked compression right?
