Another 550/750 build - Page 2
Page 2 of 15 FirstFirst 123412 ... LastLast
Results 11 to 20 of 144
    Mar 2005
    Michigan
    Re: Another 550/750 build
    I put together my makeshift spray booth and I laid the white epoxy primer down on the hull and then applied spot puddy on small dings. I still have to primer the handlepole and I need to strip the hood before I can apply primer. I'm using Kleen Strip fiberglass stripper on it, hopefully it will work. The color I'm going with is PPG Dodge Viper snakeskin green. I filled the side and top of the 550sx tray area with body filler, that turned out pretty nice, the epoxy primer sealed the body filler real good.
    1997 Seadoo SPX---limited mod
    1996 Seadoo GSX--Cruiser
    PWCToday Regular Twinstick's Avatar
    May 2015
    In the wind
    Lookin good
    1988 JS440 - OP Ride Plate & Intake Grate - Mint
    1990 650SX - Newmiller Ported, Milled Head, Coffman 3 Piece, Newmiller Flywheel, Jet Dynamics Plate, R&D Grate, Skat 14 degree, RRP Straight Bars, Quick Turn, 44SBN & Intake, Boyesen Reeds, FCV, FS Pump Cone
    1992 750sx - Plate, Grate, Fatory Limited, MSD Enhanced, Lightened Flywheel, AC Aluminum Pole, Skat 9/17, Milled Head, SBN44, Boyesen Reeds, Stuffers, FS Pump Cone, SXI Pro Rear Sponsons, Tubbies
    Mar 2005
    Michigan
    Thank you!
    Mar 2005
    Michigan
    I took my aftermarket hood that had about 5 coats of green paint and clearcoat and stripped it all today. This Kleen Strip fiberglass paint remover worked awesome! I did a couple coats of the stripper and waited about an hour then power washed it, the rest was sanded off with a DA using 180 grit paper and some razor blades. I forgot to take the before pics of the hood with the green paint, oh well lol.
    SE MI
    Damn that's cool.
    Looking good!
    Mar 2005
    Michigan
    I received my JSS coil upgrade today, time to install into the ebox! More parts coming this week, lighten flywheel and milled stock head!!
    Sep 2015
    Northern Michigan
    Nice job. Will be following your progress, great pics so far. There cant be that many 750 ss in michigan i just bought one with the same intentions. Mike ( I know Ironic)
    Mar 2005
    Michigan
    I picked my 95ss up with a nice Karavan trailer for 500 bucks! The motor had always been serviced at a local Kawi dealer and low hours!! It would've been even better if it was a 94 small pin XI motor dual carb but I think those dual carbs would drain that little 550 fuel tank real quick.
    Resident Guru Durhamgoat's Avatar
    Jun 2008
    Jasper IN
    Great deal!
    440 JS Stock
    440 PJS ski with ported cylinders, shaved head, pjs exhaust, pjs pump and exit nozzle, etc.
    550-750 Build...http://www.pwctoday.com/showthread.php?t=397055
    Sep 2015
    Northern Michigan
    Mike - what carb setup are you going to run.
