Results 1 to 10 of 15
    I dream skis ncp546's Avatar
    Jun 2012
    Milwaukee Wisconsin
    Fx1 won't start. Msd problem?
    About a month ago I had my fx1 out on the lake and when I would give it full throttle it always sounded like the carb was overloading with gas and it just didn't have the pop. A couple weeks go by and when I was riding it just completely turned off. Swam it to shore and now nothing will happen. No clicks, no turning over nothing. Bought a brand new msd ignition and still nothing. Sometimes it sounds like the ground is making a weird noise but everything is cleaned off. Tried jumping the solinoid and still won't turn over. Any thoughts?
    2014 Xscream DVX (PHP 916, PFP pipe, novi 48's, msd total loss, 155 skat mag)
    PWCToday.com Is My Home Away From Home Offroadie's Avatar
    Aug 2009
    Permanent Vacation
    Re: Fx1 won't start. Msd problem?
    Test your start/stop switch
    Quote Originally Posted by momarski View Post
    I am the one not displaying intelligence
    Quote Originally Posted by thajeffski View Post
    I'm the one here ruining the place.
    Quote Originally Posted by lakehoon View Post
    I'm local retard
    If you can't laugh @ yourself... call me.
    I'll laugh @ you!
    unplug your black start stop wire behind carb. then try to start it. just be ready to choke out engine to kill it with a rag or towel(because stop button is disconnected)
    Dec 2011
    Florida
    I had a similar problem - parked it, went back to ride 15 minutes later and nothing happened when I pressed the start button. Got the multi-meter to check resistance and worked out the start switch was no longer making contact - pulled the switch apart, a bit of emery tape on the contacts and back on the water within in 10 minutes.
    Jun 2012
    Milwaukee Wisconsin
    Tried unplugging the black and white wires. Nothing. Just a weird sizzle noise from the ebox ground
    Riverside, CA
    6
    Sounds like it seized, does the engine turn over by hand?
    Bill M.
    Oct 2013
    funky town
    Quote Originally Posted by ncp546 View Post
    Ummmm... grounds that "sizzle" are grounds that don't conduct "shizzle". Remove and clean all power and ground contact points. A little die electric grease never hurts, either.(actually, spray painting battery terminals and ground points does amazing things for longevity) AFTER THEY ARE CLEANED AND CONNECTED!!!!!
    Corrosion is like your girl. One minute you don't know she's there, the next, she's kicking your sac and inviting her mom over.
    I'm only here to make you mad
    Jun 2012
    Milwaukee Wisconsin
    Engine is free
    Jun 2012
    Milwaukee Wisconsin
    Hahaha by far one of the best things I've read on here. I'll give the grounds a dremal clean. Another thing, does the ebox have to be grounded back to how it sits in the fx1? I have it pulled out sitting ontop of the tray. I can work on my kawis with the ebox out
    Jun 2012
    Milwaukee Wisconsin
    Grounds cleaned still sizzles only sometimes. Not every time
