how to tell if pump shaft bearing is bad
Results 1 to 10 of 11
    Resident Guru runrider's Avatar
    Jul 2010
    PA
    I have my engine and my pump out. The pump shaft feels stiff. What are the bearings supposed to feel like?
    Aug 2010
    Australia
    Re: how to tell if pump shaft bearing is bad
    Quote Originally Posted by runrider View Post
    they are supposed to be smooth and free running "replace them "
    modded X2 650
    900 powered custom 650 sx .
    I dream skis hook954's Avatar
    Sep 2009
    New Hartford, CT.
    How do you get the bearings out without a press?
    Which way do they come out?
    86 X2 750... Sweet Flat A$$... Check it out
    http://www.pwctoday.com/f100/time-hu...in-268352.html
    88 X2 650
    88 650sx... Project
    Sin City USA
    Quote Originally Posted by hook954 View Post
    Shoot me your email and I will get you a PDF of the X2 Shop manual. It has detailed instructions.
    Sep 2009
    New Hartford, CT.
    Pm sent
    88 X2 650
    88 650sx... Project
    Jun 2011
    Norcal
    i can tell when my bump bearings are bad because the impeller bangs around in the pump and shears the bearing shaft off flush with the back of the prop.....
    - John Kenneth Galbraith
    Best x2 so far- 91 x2, 750 small pin 750, lightened stock flywheel. Msd enchancer, Coffman pipe, 8/16 c75 prop, tbm stuffer pjs RIP turn nozzle, 7400 rpms. GPS 54 MPH
    Sin City USA
    ^I f¨cking HATE when that happens
    Jul 2010
    PA
    Not sure if that was a joke or a very unfortunate breakdown.
    I'm replacing my bearing. The manual says to use "a waterproof grease". Can I really just use generic marine grease? All grease is waterproof last time I checked.
    Sin City USA
    Marine heavy grease.
    Jun 2011
    Norcal
    How i wish it was joke....
    I was told by impros, that it would be cheaper to get a new impeller than repair my sxr prop that this happened to. So I bought a new Hooker.
    And got an impeller 2
