kawasaki flat top pistons in seadoo 787
Results 1 to 10 of 16
    PWCToday Newbie holmes99's Avatar
    Dec 2012
    ontario canada
    i am just wondering if anyone could chime in on kawasaki pistons in the seadoo 787 engine. I am trying to figure out the best of the pistons to use.
    I am aware that the head is different.
    If anyone could chime in and guide me in the correct path way.
    thanks again
    Top Dog TMali's Avatar
    Mar 2011
    Brooklyn Center, MN
    Re: kawasaki flat top pistons in seadoo 787
    Jun 2014
    Seattle
    Better than WSM?
    78 JS440
    -Ocean Pro Finned Ride Plate
    -Westcoast Intake Grate
    -SCR Ported Cylinder
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    -Skat~Trak 16.5 SS Impeller
    Riverside, CA
    6
    Probably not important, but when I changed from stock dykes rings
    to thin keystone rings I lost 10 psi. I don't know about the thick WSM
    rings.
    Resident Guru mandriva's Avatar
    Sep 2009
    montreal,quebec
    Quote Originally Posted by holmes99 View Post
    thanks again
    Yes you could!! I build many big bore artic cat 1132cc with piston yamaha...if the chime is right ..no issue....
    Next projet..i will build a big bore 787 to 840cc seadoo with piston gp760 (85mm)..
    Rossier 7250 rpm
    110 mid pipe/200 stinger
    185 psi/Head 41cc/43squish
    Solas concord 15/23
    Mar 2015
    Villa Rica Georgia
    thanks again
    I use Wiseco kawasaki flat top pistons, and billet rossier head with flat domes in both my race boats. You will have to deck clyinders to get your squish right, ( 50-55 thousands ) if you dont the squish will be around 225-250 thousands. Rick Nolan
    PWCToday Regular twk4spd's Avatar
    Aug 2014
    So Cal/Az
    I have a question about your question ---> WHY?
    Dec 2012
    ontario canada
    flat top pistons produced better torque than a dome piston. And it is also something different to try.
    The fastest boat in my 800 open division is a 787 with kawi flat top pistons and it destroys everyone. And it is not just the rider
    Sep 2009
    montreal,quebec
    really?? Flat top pistons is better?
    Rossier 7250 rpm
    Solas concord 15/23
    flat top power depends on the porting, a lot to do with roof angle and direction. kawi flat tops are 2 deg, the only true 0 degree flat tops i know of are riva dominator flat tops. they are around 200 a piece from wiseco.
    go read waxhead's 1100 blaster build he goes over all of this. or google flat top pistons pwctoday or flat top piston greenhulk
    1994 1100 SJ - Dead
    1996 spec hx
