Results 11 to 20 of 47
    PWCToday Regular bearcave's Avatar
    Aug 2014
    Iowa
    Re: '90 Jetmate tunnel removal and hull overhaul
    Got the final large lay up done on the bottom. Should be ready for bottom paint by the end of the week.
    '95 Kawasaki 650SC
    '90 Jetmate 750
    '90 Jetmate 4-tec aka: Slow Ride
    '96 Seedoo XP
    '95 Yamaha 1100 Waveraider
    Aug 2014
    Beautiful work. Fantastic upgrade over stock.
    May 2007
    Quote Originally Posted by Cleatusjo View Post
    We hope, barecave is the first known to do this mod.
    I dream skis Dirtybird's Avatar
    Apr 2006
    St.Clair, MI
    Yah interested to see how it handles. Nice work.
    Aug 2014
    Shawn, lol
    Considering the bucket of water you lost , the hull will still be heavier. Has anyone tried A/M sponsons on these boats. My TS has a hull similar to the Jetmate. I put beach house style ( homemade ) on it and it turns like it's on rails.
    Edit: It took 15 minutes or so to learn to turn like your on a Honda 3 wheel ATV, not lean, and keep the pump in the water.
    May 2007
    What's taking so long bearcave? Any gps numbers?
    Aug 2014
    Iowa
    Been out of town, will see tomorrow if I get it back from the paint shop. When I get back right side up I still have some repairs and sealing to do on the top side.
    '95 Kawasaki 650SC
    '90 Jetmate 750
    '96 Seedoo XP
    Mar 2011
    Brooklyn Center, MN
    Interested
    Frequent Poster Graham Buchan's Avatar
    May 2015
    Cold lake, AB
    subbed
    Aug 2014
    Iowa
    Here it is back from paint, looks good and is going to end up getting scratched.
    New trailer bunks for new bottom. Contour seems to work good just laying 2x4's directly on trailer. Added angle iron to go from the bunks to the trailer.
    Removed jack nuts from bimini top from rails and made plates with nut plates to replace. Plate inside is .080 2024t3 and will reinforce the area outer is .250 plate that came with the boat. Plates will be bonded/sealed on after top plate is painted.
    Removed seized fuel shutoff valve and will replace with new valve. New valve will be ON, OFF, RES and will be usable without lifting rear seat.
    jetmate painted and trailer 010.JPGjetmate painted and trailer 011.JPGjetmate painted and trailer 012.JPG
    Making new fuel tap, original is scrap, thanks "delegram" for coming up with this idea. This is a real slick and easy way to replace the fuel tank tap. Just got all the materials and will finish up tap next week.
    Top surface gel coat woke up good with polishing so will not be painting top side. Still need to finish bilge edge sealing and painting. Getting some potted fasteners p/n NAS 1832-3-5 to replace the windshield jack nuts. When these are installed they will be a water proof without a screw installed in them.
    '95 Kawasaki 650SC
    '90 Jetmate 750
    '96 Seedoo XP
