impeller selection for a 1996 yamaha wave raider 1100
Results 1 to 8 of 8
    I dream skis needforspeed's Avatar
    Sep 2008
    New Jersey
    Harry,
    I have a prop question for you. I have a Yamaha wave raider 1100. Due to dirty carbs from the previous owner, the middle cylinder leaned out and melted down. I rebuilt the top end 1.5 over.
    My first question, Is this considered a big bore now? Most of the piston kits I found were .25, .50, .75 or 1.00 over. When I tore down the engine it was already on 1.00 over. So I had to go 1.50 over. There is no porting, the cylinders and cases are all stock.
    So the machine is running great, nice clean rebuilt carbs, fresh top end. everything is good after 15 hours on the new top end which I broke in correctly.
    I wanted to increase my performance a little and found a brand new Solas YD-SC-J impeller with 14/20 pitch for a buck and a quarter shipped. Which I thought was a good price. So I grabbed it. While waiting for it to arrive, I realized the impeller listed on Improvs impellor selection chart said this particular impeller was for a modified engine. I do not consider my engine modified. Unless of course with the 1.5 over pistons is considered a big bore. If that is the case, I don't know if my machine will spin this impeller properly for the best performance. Please advise. I am thinking I need to trade this impeller or have it re pitched.
    Thanks!!!
    If it aint broke...don't fix it!!!!
    Sep 2008
    New Jersey
    Re: impeller selection for a 1996 yamaha wave raider 1100
    Bump.....?
    Resident Guru RenoJetTech's Avatar
    Apr 2009
    Reno,Nv.
    You didn't mention if you shaved/took a little off the head, to keep comp. up.
    You went up about 40cc's and got real close to a true 1100cc, big bore in a way, but not a 1250 yet.
    Are you going with individual flame arrestors ?
    You could get that impeller (good deal) and get it re-pitched for your particular set up.
    '88 550-ride plate,intake grate,intake manfold,carb
    '96 GTX-1mm overbore,F/a's,intake grate,port timed for mid and top end
    '95 FX 1- usually take this motor to 753cc with exhaust porting and reeds
    Sep 2008
    New Jersey
    no I didn't shave the head as I didn't know how much to shave off of it. I do not have individual flame arrestors. Everything is bone stock except the pistons and cylinder bore.
    Sin City USA
    Too tall of a pitch for a stock motor. Your peak rpms will be too low. You cannot go to a taller pitch impeller alone to "increase performance", in fact you will do just the opposite, and doing this very well could cause damage to the motor from being over-propped.
    Sep 2008
    New Jersey
    exactly..That is why I am asking the question. I would love to know how much to shave off the stock head. And if the thing on my engine would be enough to spin the prop I have .....
    Sin City USA
    Even if you milled the head its not going to be enough for that impeller. You need to get an appropriately sized impeller for the engine that you have.
    I have to agree. A 13/18.5 or 13/19 will be a better bet.
