issues with Yamaha FX-1
    Frequent Poster JSmith5690's Avatar
    Jan 2006
    Mobile, AL
    Posted this in the FX1 section but not much activity over there. So I am posting again here to, hopefully, get some feed back:
    Took my fx1 out yesterday for first time in over a year. Got a couple of issues that need to be corrected.
    1-porpoises like crazy on power, no matter where I stand in the tray.
    2-bogs down right after doing a tail stand. It almost feels like the exhaust gets plugged or blocked, but not sure.
    Need some help fixing these problems.
    I weigh around 170. Ski has scoop grate, aftermarket ride plate and b-pipe.
    Any suggestion?
    Thanks in advance for any information provided!
    __________________________
    '96 Blaster--Riva Red Pipe, UMI Bars/Steering, Protec Plate, R&D Grate, JetTrim Seat
    '94 Blaster--Restored to '96 OEM Graphics and Colors, 760 engine, Dual Buckshot 44's, Factory Drypipe, Factory Pipe Waterbox, Rideplate & Grate, Hydroturf Mats,Magnum Pump
    '95 FX-1--"Real" FX1 B-Pipe, Ride Plate, Intake Grate
    '84 JS440--w/550 engine, Custom Paint, Kerker Wetpipe, SuperTrapp, UMI Bars Turnplate & Trigger, OP Nozzle and Steering Nozzle
    '96 GTX
    '94 XP
    Trinity Epic X-2
    Re: issues with Yamaha FX-1
    is this your first time riding the ski? they take some getting used to!
    this site gets a lot of action: http://www.x-h2o.com/index.php?forums/fx-1.136/
    Jan 2006
    Mobile, AL
    No. Had for a few years but haven't ridden in a year or so. But yes thesE are a hand full. Always had the porpoising problem. seemed to get worse after I added the more powerful pipe. When cruising steady on flat water, anything more than half throttle would induce the porpoising. I change my stance to minimize it but still there. Was thinking of changing stock bars to move me forward more (or shortening the pole). Heard someone once talk about shimming the ride plate rear bolts or the pump.
    The bog after tail stand problem is relatively new. Didn't do that before...
    Thanks!
    '96 GTX
    '94 XP
    Trinity Epic X-2
