    PWCToday Newbie Jakobi 750sxi's Avatar
    Jun 2015
    California
    750 sxi trouble shoot
    Bought a 01 sxi pro. Ran awesome for a couple hrs
    then started cuttin out when I grab full throttle even dying
    but I'm able to cruise quarter throttle all day, anything more it bogs
    just cleaned the carbs and diaphragm was a lil dirty out it back together ran good for 10 mins then back to the same problem? Just siphoned out the gas gonna test it with fresh gas tomorrow, plugs are good compression is 150 both cylinders?
    I tried runnin both carbs still only quarter throttle?
    Need help ha
    Jun 2015
    California
    Re: 750 sxi trouble shoot
    Tuning sorry
    Dec 2014
    Lancaster
    2
    They do get water in tank, plagued us at world finals 2002 pro-am ski stock class winner rob Flores . Up late that world finals testing, that was the beginning of stock class, Kawasaki gave free test rides on the new 03 SXR. Also check for exhaust leaks.
    Jun 2015
    California
    Yeah I ran thru the ski everything looks good
    How does water even get in is what my concern is?
    Top Dog
    Jul 2014
    Socal
    Sounds like the coil or CDI is dying. Does it run when you let it sit for a while? Are you sure it's a bog? Do you have a primer installed? If so, hit it with the primer and see if it comes alive when it starts to do that. That will help determine whether it's a leaning out issue or an actual bog.
    Jun 2015
    California
    No choke or primer
    it will run quarter throttle but when I grab full it's cuts out and wants to die
    if I let off fast enough I can keep it alive and just cruise quarter throttle
    i I have and x2 as well that will idle on the stand but when i put a load on it completly dies
